Going to try something.... ;)
Old May 10, 2002 | 10:44 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Going to try something.... ;)
You would need more stall than you have now, and basically would need a 4800-5000 stall to make a powerband like that work at the track.
I remember when Terry would jump all over TR on stuff, now he follows them. Gotta love it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 10, 2002 | 10:49 AM
Terry Burger's Avatar
Just because they are the first to post results doesn't mean they were the first to try. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Maybe I'll run a 236/236 111ls camshaft, its not like the difference between the two is that significant, lol.
With my TP4400 the rpms are almost never below 5800rpm. Perfect candidate for a 6000-7300 power band in my opinion.
Old May 10, 2002 | 10:58 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
What cam specs did ya try out, and how well did it work? It would be a nice addition to the data that's already out about the reverse split pattern cams.
__________________
Old May 10, 2002 | 11:43 AM
JS's Avatar
JS
Terry I'll admit my cars stout but lets face 200lbs is 200lbs.U cant tell me I wouldnt be in the 10's NOW if I was 3380lb.
JS
Old May 10, 2002 | 01:35 PM
Damn, let's not start bench racing!
Terry - Any info on the reverse split that was tried?
Trevor "10-second cam-only car if it was January at HRP and my car weighed 3,000#" D.
__________________
Old May 10, 2002 | 01:52 PM
Trev I don't have any specifics for you but I've seen a few of these grinds before, awhile back. It seems like TR is having decent results with them right now, but back in the day the consensus was that a 224/218 cam didn't perform or idle any better than a 224/224 cam, for example.
Old May 10, 2002 | 01:58 PM
oh ok Was anything tried with bigger duration like the 230/224, or was the 224/218 the largest one tried?
__________________
Old May 10, 2002 | 02:00 PM
Most of what I saw was in the 224 range.
 Michael S. Palmer
Old May 10, 2002 | 02:10 PM
LS1Tech Co-Founder
Usually Terry is not this vague so he is clearly just making stuff up. I don't recall MMS ever running reverse split cams back then, I could be wrong.
Old May 10, 2002 | 02:15 PM
A lot of shops try things and don't publish the results. I was just pointing out that I know TR isn't the first sponsor to try this idea, just the first to post about it on LS1TECH.COM. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
In fact I suspect the "G5" cam is a 230/224 size camshaft on 112ls. I wish someone would spend the $20 and put it on a cam doctor. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old May 10, 2002 | 03:16 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
<strong>In fact I suspect the "G5" cam is a 230/224 size camshaft on 112ls. I wish someone would spend the $20 and put it on a cam doctor. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I can safely tell you that your suspicions are wrong. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
__________________
Old May 10, 2002 | 03:56 PM
  #32
LS1Tech Co-Founder
Nope the G5 is not a reverse split cam.
FWIW I ran a reverse split lift cam last year...
Old May 10, 2002 | 04:02 PM
  #33
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Testing of these cams was big back when the turbo systems were coming out.
RE: The G5, I know it idles worse and puts out less power than my MMS 229v2.1 camshaft, but what are its specs?
Old May 10, 2002 | 04:27 PM
  #34
JS's Avatar
JS
U guys can slice it and dice it all u want,the bottem line is 248lbs is worth MAJOR ET.
JS
Old May 10, 2002 | 04:38 PM
  #35
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">JS you're not that far away from 10s just lose another 100#s and you'll be there. The funny thing with your car is you went 11.4x? with inexpensive streetable parts, and now go 11.17 with tons of high end race parts. It's funny to me, all that work for so little gain, you know? I'm sure you'll get in the 10s with a little more weight reduction.
I'm sure I could run 10s right now at the right track. I'm just having fun here trying new parts with my car like I always do, seeing if I can put myself in a position to compete with Scott, John, George, and the other really quick 346ci A4 guys. I think if I take another 150# off, add another 25rwhp, and drive to a track with 500' da or better, and get a 1.4x 60' time I'll have a shot at 10.6's. By the time I get there everyone else will probably have already run 10.3, but at the moment its still a fun goal to try for. Besides there are like 10 guys ahead of me on the waiting list for MMS 388 motors, so I have a little time. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old May 10, 2002 | 04:50 PM
  #36
JS's Avatar
JS
Terry I did some calculating and 60RWHP is worth 4 tenths TOPS in a car already running 11.4 so I'm not that far off.
I do agree the sum of the parts just dont add up.
Once u start running 11.40 and quicker ET becomes harder and harder.
JS
<small>[ May 10, 2002, 05:22 PM: Message edited by: JS ]</small>
Old May 11, 2002 | 12:46 AM
  #37
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If I could cut a 1.53 60' time at Famoso raceway I'd be in the 10s too. So what?
Old May 11, 2002 | 10:02 AM
  #38
GeorgeC's Avatar
<strong>So when does your mini superstroker go in? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You mean my stock crank (not even offset ground) .050 over beast? Hopefully I'll be starting on the install Monday (2 more days)...
With any luck (or with a lot of luck), I'll make some shakedown passes next weekend. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 11, 2002 | 10:31 AM
  #39
I thought the crank was offset ground, thats why I was calling it a mini superstroker. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
