Help, what do I look for on surging problem??
Old May 9, 2002 | 05:09 PM
SB's Avatar
SB
Default Help, what do I look for on surging problem??
I have a 99ss camaro with b1cam and flp headers w/orp.
A surging problem started about 2 weeks ago which I have never had before. When I am at partial throttle anywhere from 2k rpm to 3500 rpm the car surges bigtime. Also it is throwing more SES codes all of them being p0300 engine misfires. I'm also getting more backfires after letting off the gas. Again the surging problem only happens at partial throttle and not a complete stop at idle or at wideopen throttle.
I changed out the fuel filter and took off my maft translator but this didn't help. When I floor the car it runs real strong and after an atap I'm getting no KR and timing is avging 27 degrees with the HPP3 nonrfg tuning. The car currently has 37k miles on it.
Does anyone have any ideas what I should look for next??
Thanks
steve
99ss m6 with b1cam and flp headers w/orp and all boltons with fikse fm10 rims
<small>[ May 09, 2002, 05:11 PM: Message edited by: SB ]</small>
Old May 9, 2002 | 05:56 PM
Doug Tschantz's Avatar
Default Re: Help, what do I look for on surging problem??
Check your TPS voltage and IAC counts.
Doug
00 Pontiac
Old May 10, 2002 | 07:32 AM
SB's Avatar
SB
What kind of numbers should I be looking for on the tps voltage and iac count? And is this measured at partial throttle?
thanks
steve <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old May 11, 2002 | 06:55 AM
SB's Avatar
SB
ttt
Old May 11, 2002 | 11:59 AM
TPS should be between .5-.7 at closed throttle. IAC counts should be 35-40 at idle. Adjust the throttle blade screw for both of these. Is the throttle body stock? Usually people will drill out the hole in the throttle body to 13/16 for a better idle. In your case though if it's happening in the mid-range I would say check all plugs and wires, and everything electrical. One time a didn't get a plug wire on all the way and this happened to me. Car would surge at midrange and idle alright. Good-Luck !
Doug
00 Pontiac
