Arp Head Stud tensions
Old May 11, 2002 | 04:13 AM
VAP's Avatar
VAP
Default Arp Head Stud tensions
Just bought a set of ARP head studs for the LS1 and was wondering what everyone is tensioning the nuts (studs) too ?
The paperwork that came seemed very general stating 65 ftlbs with moly which seems about right but just wanted more or less someone to confirm this for me please.
What tension are the smaller studs done too ?
Thanks.
Old May 12, 2002 | 04:25 AM
VAP's Avatar
VAP
Default Re: Arp Head Stud tensions
Anyone ? <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 12, 2002 | 05:02 AM
LS1derfull's Avatar
I dont have them but i plan on running them. I would install in block hand tight, use Arp lube not just any moly and torque to their recc. torque with their lube. That is critical. I would plan on retorque after driving and cooling down.The studs set and gasket settles, making retorque necessary. If that sounds like too much work, i would torque gaskets and let sit for several hours than loosen nuts and allow that to sit for a while.Than retorque finally, this procedure is almost as good, but doesnt require you put it all back together, run and dissassemble again. What gaskets are you going to use?
Old May 12, 2002 | 06:16 AM
Plan B's Avatar
Gee! I’ve got them and have always just gone reasonably gentle on those little guy’s. It’s kind of a feel thing. No big issue, they don’t do much anyway!
With studs, pulling through/from the engagement of the thread, you can get out of trouble by a week.
Just for practice. Three of us one night, measured the difference with torque to yield bolts, (angle gauge) over the ARP set up. We logged all settings. 25 - 28 flb’s on the little ones, you are referring to.
I’ve run the old gaskets and the new, with no issues.
Old May 12, 2002 | 06:53 AM
LS1derfull's Avatar
Hey Peter do you have MLS gasket thickness spec?
TIA
Old May 12, 2002 | 06:21 PM
Plan B's Avatar
Yep. I've got an "average" crushed thickness of .052" at the outside lip of the head. I suggest it may be little tighter around the studs though.
Old May 12, 2002 | 06:26 PM
LS1derfull's Avatar
Thanks dude, that settles it i am going to run Felpro for best seal and its only .042" thick.
Old May 12, 2002 | 06:35 PM
383LQ4SS's Avatar
I use 75 ft/lbs on the big ones and still use 22 ft/lbs on the little ones. Thats with MLS Cometic gaskets.
Old May 12, 2002 | 06:47 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 383LQ4SS:
<strong>I use 75 ft/lbs on the big ones and still use 22 ft/lbs on the little ones. Thats with MLS Cometic gaskets.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nice power and times dude!
