dual valve springs?
This setup has worked very well in the past.
There is also a chance of breaking through when the spring pockets are machined out do to casting inconsistancies and/or port work. If that happens, you will have to get the break welded up and re-machined. Also more $... But if you are planning on doing this, now is the time.
You could still run the 918's for now since the springs are located by their centers, not their perimeters...
Shane
<strong>Thanks, Im probially gonna go ahead and get them machined and just put the 918s. How hard is it to install the springs while the heads are on the car?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its kind of a *****, but not impossible. as you might imagine, the front sets are easy, the back, well the back is a bitch. The double springs might be a good deal harder to do due to the pressures involved. If I was going to properly set up a double spring valvetrain, I would take the heads off of the car and do it right... I.E. measure each installed height and shim as necessary. When you install your heads this time, why not stud the block and use the Cometic or Fel-Pro gaskets. This will allow you to easily pull the heads next time...
Shane
Shane
Shane
