Wanting a biiger cam, will this work with stock heads
Old May 13, 2002 | 08:01 PM
BlackhawkSS's Avatar
Default Wanting a biiger cam, will this work with stock heads
wanting nineballs "T2" but only if it will work with stock heads. will i have any piston/valve clearance prob232/232 duration @ 0.050" lift
285/285 duration @ 0.006" lift
0.574/0.574 lift
112 LSA
Approximately 2K miles on it
Manufactured by CompCams
"R" type lobes
also would this work with the current 941 springs i have?
i would like to the throw this in the 346 and get some numbers for you guys <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jerry
Old May 13, 2002 | 09:34 PM
gator's 99TA's Avatar
Default Re: Wanting a biiger cam, will this work with stock heads
that is a LARGE cam and you would be spining the motor way up in the powerband. be ready to spin it up to 6800 rpms or better. it was made for his bigger ci motor.
but yea, it should work
Old May 13, 2002 | 10:58 PM
MyLS1Hauls's Avatar
That lift is too big for 941s, and like previously said...that cam is too big and is for a larger motor.
Brad
Old May 13, 2002 | 11:00 PM
thx kinda figured <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 14, 2002 | 12:12 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BlackhawkSS:
<strong>wanting nineballs "T2" but only if it will work with stock heads. will i have any piston/valve clearance prob232/232 duration @ 0.050" lift
0.574/0.574 lift
112 LSA
"R" type lobes
Jerry</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you go that route at least get it on a 111 lobe sep so it will bring the power down.Oh it will kill those springs.
Old May 14, 2002 | 12:29 AM
Mustangkiller7's Avatar
Well i hope that you like to change valve springs every 5K. Because those will not last with that cam,
Old May 14, 2002 | 01:05 AM
VINCE's Avatar
Shorty Director
Get some 918's and put the cam in.. Get some 4.10 gears and you will be flying.. You will probably dyno higher than any stock headed car.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
