Yes one more cam question
Old Feb 1, 2007 | 08:30 AM
TXSilverV's Avatar
Bad Trader Warning!
Default Yes one more cam question
I know there is a cam guide but I don't know much about engines so it does not help me. I was thinking of changing my cam and wanted some help. If I change out the current cam I have will I gain more power/Tq? anything else I should change to get my power? My mods are in my signature line. I was told to do a 383 stroker but how much would that cost. My budget is limited so it may be to much for me. Can someone help? Thank you!!!!
Old Feb 1, 2007 | 10:16 AM
99blancoSS's Avatar
What intake are you running? 90/90 unless your there already, you dont say what your driving. lsx? You have a decent size cam in there now but you can always go bigger. You might lose a little torque by going bigger but you'll gain HP. a 383 will cost you around 3500-4300 depending on who builds it but then you might as well go 402 or 408 for 4500.
Old Feb 1, 2007 | 10:32 AM
TXSilverV's Avatar
Bad Trader Warning!
Sorry! It's a 2004 CTS-V with the LS6. I have the stock intake on it. I have ported heads and was told they flow at 325. Does that info help?
Old Feb 1, 2007 | 11:04 AM
99blancoSS's Avatar
Yep. a 90mm intake will help out(unless those have a 90 from the factory?). You could step up to a higher lift cam but then you might need to flycut your pistons. If you dont mind doing that you can go higher lift. Like my cam for example. Its a 234/240 112 lsa .637 .640 Your heads flow so it would be a good combo I would think but certainly not the only choice in cams to be made. Contact a sponsor and haver them spec out a custom cam for you. PatrickG does it for $25 on here as well and has a deal with Thunder Racing to grind it for a discount.
