Thunder Rocker Set
Old May 14, 2002 | 09:34 PM
BEASST99's Avatar
Default Thunder Rocker Set
Is the Thunder Racing set worth it and can it handle 500 or 600RWHP?
Old May 15, 2002 | 07:04 PM
The Derek H's Avatar
Default Re: Thunder Rocker Set
Rocker set meaning roller rockers I assume. Are you asking about the Crane Golds or the T&D's or a set of Jesels. The Crane's are worthless unless you have a low lift cam and don't want to change it. The T&D and Jesels are adjustable which is a plus but not needed unless you have a solid cam. Let me know what you are referring to by Rockers because I might not have answered your question. And all of the above options should handle 500-600+rwhp easily.
Old May 16, 2002 | 08:07 PM
SSINFUL's Avatar
Funny phraseology. I'd say the Crane's are "valuable" & "worthwhile" with a lowlift cam. Not a great bang-for-the-buck, but they do open up the engine's ability to suck air in, since what they do is basically improve/speed up the ramp rates of the cam.
If I was going after that kinda rwhp, I'd be doing shaft mounts, and not the single posts.
