Motor experts inside I need help with...
Old May 19, 2002 | 03:56 AM
AlonzoVersion 1.0's Avatar
Default Motor experts inside I need help with...
I need help with cam choice.My heads are milled 30thousanths and I am getting .40 thick headgaskets which should bring it up to the 11:1: area.I was looking at cams and wanted to know if the comp 224/224 dur .581/581 lift cam or c2 would fit without piston to valve clearance.If not what is the biggest someone has gone with compression being that high on their cam?Very important to me because I dont want to change heads or cam anymore.Thanx everyone. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old May 19, 2002 | 11:21 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Motor experts inside I need help with...
what diameter are your valves? Stock?
Old May 19, 2002 | 11:35 AM
6-SpeedZ's Avatar
I am also very intrested in this, as I am considering the same cam as Booker, and would also like to know. I will be running stock heads.
Old May 19, 2002 | 02:06 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>what diameter are your valves? Stock?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Stock on the exhaust and 2.02 on the intake.Thanx everyone.
Old May 20, 2002 | 12:00 AM
SSINFUL's Avatar
You should still have .070 - .080 valve clearance.
I have .570 lift w/ 218/224 durations (108 CL- 112LSA) and have approx .090 clearance...
