Oil In the Intake!
I have oil in the intake. Not just a little oil in the intake, but a lot of oil in the intake. I have so much oil in the intake that there are oil puddles around the intake valves. When I pulled the headers off, oil came out with the header gasket! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> .
This is waaay to much oil for the PCV system. Plus I have the inline filter mod.
What can burp this much oil into the intake.
If the PCV system is plugged or not working, could positive crankcrase pressure push this much oil up into the intake???
Valve Seal??
Have I blown a ring??
For a background, the car ran fine, no discernable power loss. No problems. I did notice that I was burning a lot of oil, but didn't think it was this much! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I did notice from the sparkplugs though, that the car was running lean. Everyone of them was snow white, which worries the hell out of me.
Any suggestions. What could get this much oil up into the intake. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ May 19, 2002, 09:18 PM: Message edited by: NoGo ]</small>
Tony
I had just as much oil in my intake as I had under my valve covers <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I about **** my pants when I pulled off the throttle body.
If it is the PCV system, then there has got to be a better solution for this. Obviously, I can't continue running the car like this. There is oil in the friggen headers! <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> PCV
Time to start looking for a separator.
I had my vacuum assisted, I just never had a chance to sort out the issue of the pump sucking oil out of the valve cover.
You need the LS6 fix part# 12568002. GM has finally figured this out. In the meantime you can get #12572717 in place of the PCV valve to slow things down.
I have pictures I will soon post on my website. I am installing on Saturday.
Good Luck
<strong>You need the LS6 fix part# 12568002. GM has finally figured this out.In the meantime you can get #12572717 in place of the PCV valve to slow things down. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is this LS6 fix? Are you recommending another part # because it's not out yet?
This is how I fixed it on my car:
1) Removed the PCV hoses from the intake and throttle body. Plugged holes with set screws.
2) Rerouted all the hoses so that both valve covers were connected.
2a) connected the hose on the driver's side valve cover to the back plug on the passenger's side.
2b) put a small breather on a piece of hose and connected it to the front plug (so everything could vent naturally).
The car now comes to idles better now. It used to be that when I would rev the engine and then jump off the pedal; the engine would stumble a little (because there was still more air moving through the PCV than the engine knew about). Now it goes right down to 750 and sits there.
This summer I may use the old AIR injection system pump as a crank case pump.
Has anybody ever looked into using air/oil separators. For example, those that are found on compressed air systems?
Or air/oil separators used on aircraft engines?
<strong>It just takes forever to get the LS6 valley cover. They are on perpetual backorder... Took 2 months to get mine.
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got mine in 3 days from Valvegod <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>The part number for the rediculously priced 180 degree hose is #12568010. It is $54 while the whole vally kit is $37 and change. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats exactly why I'm fabbing my own hose for less than 5 dollars with soft copper tubing <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
