hammer cam (or similiar) what is your idle set at?
Old May 20, 2002 | 01:31 PM
BlackhawkSS's Avatar
Default hammer cam (or similiar) what is your idle set at?
just wondering where you guys have your idle set at in park, currently i have gotten it down to 725 and idling with no surge when its WARM. when i first start it up tho i have have the throttle blade cracked slightly with my foot on the pedal til it gets warm. but damn! it sounds sweet <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
just wondering if i should try going lower. i started out at 850 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> and been playing with the TB hole and idle set screw for the past 3 days to get it like it is.
Jerry
Old May 20, 2002 | 03:45 PM
SidewayZ-28's Avatar
Default Re: hammer cam (or similiar) what is your idle set at?
850 drive, 950 park...she idles perfect..kinda hunts for the idle when I first start her up, but no stalling what so ever, even in reverse! <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old May 20, 2002 | 04:54 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
800-825 in gear and park It will sometimes have some surging problems when the engine is cold if I'm creeping along, but once it's warmed up it's just fine.
__________________
Old May 20, 2002 | 05:11 PM
XTREMEZ28's Avatar
will hopefully know by tonight how it works.. but i am putting the hammer cam in and using ls1edit we are setting the idle at 830 or so warm and 950-1000 in park.... is that too high??
Old May 20, 2002 | 09:11 PM
950 park is cool..when I first start the car it'll jump up to 1100..then settle down to 950 after warming up.
I think you should be able to get away with 830 drive..you'll get a little more lumpty lump though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ..f-it try 800!
peace
Old May 20, 2002 | 09:34 PM
no way that is way to high IMO. it takes away from the sound of the cam big time. idealy you want it as low as possible. thats kinda the idea of why i made the post as it seems alot of guys get tuning and just get it stuck at high *** rpm's cause the tuners dont wanna take the time to make it idle right. with some tweaking and what not and playing with ls1 edit i have my idle set up like this with no AC.
in park start out at like 1400 and work down to 725 at 176 degress on the ls1 edit chart.
in drive start out at 1000 and work down to 700 at same temp.
then you gotta mess with the hole in the TB and the idle set screw both are very touchy. i have the screw almost completely down. and the hole is drilled 1/8th, yes 1/8th..... and my IAC's are at the 20 range at 190 degrees.
so with this said hopefully this will help some guys wondering bout how to set up the idle, specially if your looking for lope <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
if you dont have ls1 edit the you suck <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Jerry
Old May 20, 2002 | 10:02 PM
The tuners are pretty quick on jacking the idle up too high. I know that my "recommended" idle was 950, and I said no way. I have the cam working perfectly at the idle above, and it still is low enough to sound great.
__________________
Old May 21, 2002 | 11:34 AM
Jerry, did you take her for a test drive? Any stalling? Surging? Does she shake?
Just curious, what do M6ers idle at stock?
Old May 21, 2002 | 11:53 AM
02 SOM WS6's Avatar
I'm getting a Hammer cam installed Friday at MTI. I am curious to see how it turns out.
Les
Old May 21, 2002 | 04:16 PM
yes i drove it all day yesterday and today. like i said to start it i crack the gas pedal very slightly and remove it once it starts.then once its warm i have ls1 edit having it idle at 725, very sweet, nice smooth lope, no stalling or surging at all.
in drive it idles at 700 and is just as smooth and sweet at stop signs and what not. very pleased.
i just hate the added noise of the valvetrain, glad i got a loud *** exhaust <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jerry
Old May 22, 2002 | 12:54 AM
Raughammer's Avatar
D(irecto)r Pepper
You'll like it Les.
I use 850 at idle.
Old May 22, 2002 | 02:17 AM
TBaGZ's Avatar
Wow.....you got that thing in already?!!
really wish I coulda got back to you sooner on grabbing your old cam.
Old May 22, 2002 | 05:02 AM
actually its up for sale again <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old May 22, 2002 | 06:39 AM
2000 Camaro SS's Avatar
BlackhawkSS
With your idle that low, when you come to a stop light (from like 25 to 30 or so) if you stop "FAST" does the car stall? Almost stall? Does the idle drop down below 650 or so? If not what would you attribute all of these things "NOT" happening to? When my cars idle was that low these things would happen.
Old May 22, 2002 | 07:25 AM
well i havent tried screaming down the road and slamming on the brakes lol, but from the regular day to day driving i do it hasnt done that yet, has never stalled or stumbled. just regular to moderate stopping. hope i dont expereince that at the track slowing from 120+ <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Jerry
Old May 22, 2002 | 06:58 PM
i got rid of like 80% of the ticking by tightening up the the ypipe to header bolts, they were fairly loose, even got rid of more ticking by tightening them up with my extented pipe <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> and cranked the **** out of them, sounds alot better without the ticking in the wheel wells <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
i suggest everyone check theres as maybe they loosen up or mine never got completely tightened.
Jerry
Old May 25, 2002 | 09:50 AM
AINT SKEERED's Avatar
I just got my car back on the road, Hammer cam ,stage1 heads,Mac headers and centerforce clutch. The cam hunts for idle when I first crank it but then Idles at 800 just as sweet as can be.I have a Edelbrock catback with mac orp and have 0 resonence or drone. This car sounds AWSOME! Quiet at idle but loud as hell at wot, I just want it to stop hunting on crank up. what can I do to stop this?
Old May 25, 2002 | 10:03 AM
how long does it hunt for and how wide is the range? when mine did that i had to tighten up the throttle body hole just a little bit, very little if its only on start up. or try to adjust the idle set screw bout 1/8 turn up
