Bad bad news for my car
Shrt of dissasembling, no.
You can check compression after you put it back together. If you're doing the work yourself, you'll loose mostly labor time and some fluids/sealant. Cometics are reusable, your heads would be fixed.
Just clean the pistons with mineral spirit and use a magnifier with UV light to see if anything is visible from the top at TDC.
That would be tough with the head off. Even after you assemble it, a compression leakdown test would help, but you ideally want to run it on a hot engine.
On another note, is ETP sending you new springs, or are you sending the heads to them? Perhaps they can check the guide and replace the valve for you. Either way, props to them for volunteering to replace the springs.
Originally Posted by PREDATOR-Z
IMO they should take the heads back and fix everything, including shipping back and forth.
And who says duals are good insurance hahaha
It is not bad man, what I would do is flycut all the pistons, get the heads checked (fix bent valve), put thinner gaskets if you do not allready have them. This way you turn tragedy in optimum combo
When it comes to fixing this, leave no stone unturned. As others have said, check the cam, lifter, piston. There are more than a few people who have "assumed" that the rest "should be okay", only to discover that they are now having to rebuild because something let go that was not checked. Realistically, I "doubt" you have "hidden", but I am pretty **** about checking stuff as "insurance". me----> <----me
Originally Posted by Detroitmuscle
I will be sure to examine everything thanks for the great information guys I really appreciate it all. Just out of curiosity how much would you figure a forged 347 (nitrous motor) would run me if I handed the short block off to a local shop?
Can I build a reliable forged motor with rods and pistons (stock crank)? The most I would ever run would be a 200 shot but probably just 150 for a while.
3.903 bore
6.125 rods
3.622 crank (micropolished), you could even nitrate the crank and shoot 400 on it if you want.
#33
Any ideas of prices on the whole thing? Can it be done for under 2K?
#36
Originally Posted by david vericker
yes parts only - machining and assembly will run you considerably more. 5.5K total if your lucky.
#37
Thats more of what I wanted to hear how much does assembly usually run? I figure I can do pretty much everything myself to save some coin aside from the machine work but I really wouldn't wanna risk this kind of cash learning how to build my first motor. Machine work should run no more than $400 and the rods and pistons are about $1000 so if I could find a shop to do the assembly under $1000 I'd be very happy.
#38
Damn, if it's that cheap, I might be just getting some forged pistons and getting my block overbored this summer.
Hello direct port. I even have a spare intake manifold to start designing plumbings on.
#39
Originally Posted by Beast96Z
For a 347? $2500-3k tops......$5.5 will get you a bad *** stroker motor.
forged h-beam rods and mahle pistons... $750
machining the block and crank.... $350 (included cam bearings and install)
balancing the rotating assembly... $175
rod and crank bearings... $150
i saved a few $$$ assembling it myself and file fitting my rings
#40
