TR224 guys questions????
Old May 21, 2002 | 11:28 AM
BadMonkey's Avatar
Default TR224 guys questions????
I have aquired a TR224 cam with a 112 lsa. All I plan on doing is replacing the springs and the pushrods, is there anything else ( I am replacing the timing chain as well) that I should need to worry about. I plan on getting CC 918 springs, what pushrods is TR using in thier kits? I am leaving my heads stock for now. Just want to see what some of you would recommmend
<small>[ May 21, 2002, 11:30 AM: Message edited by: bd mnky ]</small>
Old May 21, 2002 | 04:01 PM
MY99TAWS6's Avatar
Default Re: TR224 guys questions????
Well thats news to me about the gm lifters.I am pretty sure lots of guys here are running their similar cams to 6500 and a bit beyond.And considering its such a pain changing lifters in the ls1 I thought I would wait till next year when I do new heads.The ls1 lifters can't be changed with heads on like the lt1 and earlier small block chevy's. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 21, 2002 | 04:07 PM
ONEBADWS6's Avatar
I take mine to 7,000 with no valve float.
Old May 21, 2002 | 05:44 PM
BadMonkey's Avatar
Thanks guys, so I should be ok with new push rods from CC and the 918's on the stock retainers right. Cause that is all I am going to do until the head gets reworked
Old May 21, 2002 | 06:09 PM
Smoke_ur_5.0's Avatar
918's, 7.40 stock length comp cam pushrods should be more than adequate.
Your stock GM lifters will work just fine up to 6800-7000rpm. Besides Comp Cams is a on a mucho factory backorder for theirs and have had a few failures from a few people.
Old May 21, 2002 | 09:43 PM
BadMonkey's Avatar
Thanks again Mark......
Old May 22, 2002 | 12:06 AM
Jason99T/A's Avatar
I can shift faster than you.
Ditto what Mark said.
Old May 22, 2002 | 12:24 AM
gator's 99TA's Avatar
NICE damon!!!!!! timing chain should be fine and you will need a big ole rev limitor to spin that motor up now! cant wait for the sekrit mod! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> CC has pushrods for thier cams available. stock length or just a bit shorter is available (depending on the base circle of the cam).
Old May 22, 2002 | 12:30 AM
BlackWS6LS1's Avatar
If you plan on revving past 6250, then you should plan on replacing the lifters. GM only rates them to that RPM...
Tom
