thunder 230/224 with rgr s2 milled to11:1???
will i have enough piston to valve clearence with the thunder 230/224 .569/.563 111 and stage 2 rgr heads milled to 11:1?
LSX Mechanic
Re: thunder 230/224 with rgr s2 milled to11:1???
You will definately want to check with Thunder first before milling those heads at all. The clearance for that cam on stock heads is very tight, and they aren't even sure that any milling can be done safely without fly cutting the pistons. Check with thunder before doing anything. When I ordered this cam 3 weeks ago, they were not very confident that there would be much room for milling, however they are checking very soon on clearance with this cam..
josh
josh
