Head bolt tap sizes?
Old May 22, 2002 | 03:36 PM
Scalpel's Avatar
Default Head bolt tap sizes?
My brother and I are replacing the heads on his SS and I need to know the tap size for the head bolts so I can clean them out. Thanks.
<small>[ May 23, 2002, 09:09 AM: Message edited by: NastyC5 ]</small>
Old May 24, 2002 | 03:11 PM
Scalpel's Avatar
Default Re: Head bolt tap sizes?
TTT
Old May 24, 2002 | 03:28 PM
Reckless's Avatar
Super Moderator
It's really coarse, like a 12mm x 1.25 I think.
Old May 24, 2002 | 04:59 PM
1madss's Avatar
If you can't find the right size, you can use the JMX method of grinding a slot in one of the old head bolts and using that as a cleaning tap. This is what I did and it works pretty well, plus its free <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Mark
Old May 24, 2002 | 07:53 PM
rumbleme's Avatar
I would not chase the treads with a tap. If you chase the treads with a tap it will remove material and weaken the treads. I know I did it once, dumb. I had to have treaded inserts installed to fix it
The tool you need is referred to by SNAP-ON tool as Metric Retreading tool. I would just blow the holes out with air.
Information can be found on page 6-483 and 6-484 of 2001 factory manual. Size is M11 X 2.0
