What is wrong with my car!! Need Help!!
Old May 23, 2002 | 05:07 PM
99LS1Z's Avatar
Default What is wrong with my car!! Need Help!!
This has just happened. I was sitting at a stoplight when my car was making a wierd noise. I turned the AC off and the noise stopped. I can turn the AC on with the air blowing on the lowest setting and I can hear a noise coming from the passenger side around the glove box. Each time you increase the setting to make the air blow harder the passenger side dash vibrates louder and harder. It sounds horrible. You can turn the setting to where it is blowing out the hardest and the entire dash vibrates very loud and hard and it sounds like something is really screwed up. Please help me find out this problem. Thanks
Old May 23, 2002 | 08:27 PM
NoGo's Avatar
Default Re: What is wrong with my car!! Need Help!!
If I had to guess, I would say it is you AC compressor. But I'm not very familiar with the AC system.
Who needs climate control anyways. Toss it, it's too much weight. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 24, 2002 | 12:35 AM
XtraCajunSS's Avatar
You either a)have a small animal or piece of debris in you blower under the dash or b) have a blower motor going out... That is the exact location of the entire blower assembly for you heat, vent, A/C, and defrost system... This has nothing to do with the compressor. (not if the dash was vibrating)
Shane
Old May 24, 2002 | 02:40 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XtraCajunSS:
<strong>You either a)have a small animal or piece of debris in you blower under the dash or b) have a blower motor going out... That is the exact location of the entire blower assembly for you heat, vent, A/C, and defrost system... This has nothing to do with the compressor. (not if the dash was vibrating)
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I second that if the dash is rattling as well.
Old May 24, 2002 | 03:33 AM
35th SS's Avatar
blower motor going out or blower fan worn,misalign.
Old May 24, 2002 | 06:39 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Good suggestions....our truck was making a similar noise and it turned out to be a heater hose vibrating against an engine bracket.
Old May 24, 2002 | 06:56 AM
dfarmercse's Avatar
whit vibrations getting louder with speed you could have a balance problem with the fan. Bad fan or something in the blades throwing it out of balance.
Old May 24, 2002 | 10:02 AM
99LS1Z's Avatar
How do I take the blower motor out? I looked under the dash and I could not figure out How to take that black cover off to get to the blower motor. Thanks
Old May 24, 2002 | 10:30 AM
dfarmercse's Avatar
It has two tabs in the front under the glove box. Not sure how to release them. You can take your glove box out by pushing the sides in and pulling out. That may give a look at how those tabs are held in.
Old May 24, 2002 | 10:33 AM
dfarmercse's Avatar
When you get the cover off, remove connector and the 3 screws then motor comes right out. You should unhook your batt since you air bag sensor is in there and you don't want to bump it and set off your airbag.
