382 all bore guys............
Old May 23, 2002 | 05:50 PM
Ls1 382ci SS's Avatar
Default 382 all bore guys............
what cams are you guys running? I was wondering what was the biggest cam in an all bored 382 motor is? I currently have a 230/237 .544/.544 114
how many with R1 cams? anyone with a much bigger cam? Anybody have a 237/242 114 cam? <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Old May 24, 2002 | 08:21 AM
AJH LS1 Z28's Avatar
Default Re: 382 all bore guys............
I am running a MTI 382 All-Bore with LS6heads and the R1 cam!! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old May 24, 2002 | 10:13 AM
sweet, there are't that many 382 all-bore guys around from what I can see.
Old May 24, 2002 | 10:43 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I think the cam you have is pretty good. The R1 really works well in those all-bore motors.
Don't get crazy with those huge exhaust durations, they really don't help much. Notice how well Thunder Racing's reverse-split patterns are doing?
I started with the T1 (221/221 .558 112) on my 382ci and it pulled 455 rwhp/442 ft-lbs with the stock rearend. Swapped to the T2 (232/232 .574 112) and pulled the same numbers thru the new 12-bolt/4.10 combo. I figure it was worth about 10 rwhp over the T1.
Tony
Old May 24, 2002 | 02:52 PM
badls1's Avatar
i am on 370ci and running on R1 232/237 561/561 112. works fine, very strong top end but its 12 to 1 ratio
<small>[ May 24, 2002, 02:53 PM: Message edited by: badls1 ]</small>
Old May 26, 2002 | 04:04 AM
blackLS1's Avatar
What is the 382 all bore?I thought the 382 was just a stroked LS1.Are there two versions of the 382?
Old May 26, 2002 | 11:12 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Two ways to create a 382ci LS1:
1. Stock bore/block with a 4.00" stroker crank
2. Resleeved/bored block with 4.10" bore size and stock crank.
Stock bore is 3.90" diameter.
Stock crank is 3.62"
MTI has also produced an all-bore 393ci setup and it is being tested in SW's Corvette. This uses the same 4.155" bore as my 434ci (I have a 4.00" stroker crank).
Tony
Old May 27, 2002 | 03:04 AM
blackLS1's Avatar
Thanks NineBall.Not to jack the thread but I hear and read(a little)about SW's car.Is there a site were I can learn more about his cars?
BadLS1 How is your 370?What crank or bore was used? Thanks guys. <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old May 27, 2002 | 02:59 PM
The Guy in MY 99TA's Avatar
Someone else built a 393 and it was in a Silver z28. I think it might have been ARE( I may be wrong) But that car made some great numbers. I saw this car in a magazine article. I'll see if I can dig up some info on it.
Josh S.
Old May 27, 2002 | 04:42 PM
Crazyquik's Avatar
That car would be cendres' 98 Z28, ARE built the engine. It was a 393 with a solid roller cam, resleeved to 4.10 bore with an offset ground stock crank.
J.
Old May 27, 2002 | 09:32 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Crazyquik:
<strong>That car would be cendres' 98 Z28, ARE built the engine. It was a 393 with a solid roller cam, resleeved to 4.10 bore with an offset ground stock crank.
J.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">DITTO! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jun 8, 2002 | 02:40 AM
JP98SS's Avatar
Bringing this one back from the dead. Looking for a bigger cam to drop into my all bore. Currently running a 229 cam. Any suggestions? Also stepping up to 1 7/8 headers and 3.5" collectors. Currently running Stg III 6.0L heads and 11.2:1 compression. Noticed that the MTI R1 cam is backwards according to the current logic. Seems like according to the current trend we should flip it around and make it a 237/232 cam. What was the initial logic behind the larger exhaust duration on the R1?
Old Jun 8, 2002 | 02:11 PM
badls1's Avatar
well i am runing on stock stroke, re sleeved block. its on 4.020 now. i wanted a engien with less then 380 to have less friction and rev a bit high. but on the same sleeves i could punch out another .040 if i want to. but not needed for now. its acually 368 cubs. depends what gasket i might use i could play around from 11.5 to 12 to 1 on the comp.
