Simple bottom end build question
Old May 24, 2002 | 01:23 PM
Obliviously Obvious's Avatar
Default Simple bottom end build question
I have a bare block and all my parts that need to go in it, but, my simple question is, when I install the cam, and install the crank, put the gears on, etc, etc, and I line the crank and the timing gear up, dot to dot, where should my pistons be? #1 at TDC?
Old May 24, 2002 | 01:25 PM
Big Mike's Avatar
Default Re: Simple bottom end build question
Come on, that answer should be Obvious! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I just had too.
Old May 24, 2002 | 01:51 PM
Scalpel's Avatar
Pistons 1 & 6 will be at TDC with the timing gears dot-to-dot.
Old May 24, 2002 | 01:52 PM
Yeah Yeah, I know it should be. This will be my first build.. I just don't know, and don't remember seeing it in the Helms books.
Jen <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old May 24, 2002 | 01:55 PM
Thank you NastyC5 !
Old May 24, 2002 | 02:12 PM
Scalpel's Avatar
Not a problem.
