Loud valvetrain after cam install???
Old May 25, 2002 | 01:16 PM
dfarmercse's Avatar
Default Re: Loud valvetrain after cam install???
to reset the PCM. turn on key and remove the two PCM fuses under the hood. wait 5 min, turn off key and reinstall fuses. Start car and let idle for 5 minutes to relearn idle and do system check. If it is a auto, put in gear and let it idle another 5 min.
Old May 26, 2002 | 12:21 AM
ls1formula99's Avatar
Default Loud valvetrain after cam install???
I just installed a hot cam in my 99 ls1, Car started and ran fine but the valvetrain is very noisy. Sounds like ticking from both sides, is this normal? was told that it could be due to the faster ramp rate of cam and that most become more noisy after cam install. Anyone have same problem with hotcam? also how do you reset the computer? any input would be great. Thanks Ryan
