Rocker Arms!!!
Old May 25, 2002 | 10:38 PM
Jackyl_30's Avatar
Default Rocker Arms!!!
I heard today that the company that makes the arm itself is going under. So what rockers are out there now is all that is left. There is going to be a lot of back ordering or something. Apparently Crane and all the other companies get the rocker "shell" from some other company and then add all their little parts themselves. If this is true, then there are going to be a lot of delays.
Old May 26, 2002 | 02:42 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Rocker Arms!!!
Jesel S/S rocker arms in the stock 1.7 ratio are only $695 retail and fit under the 99+ valve covers with a little modification to the covers. That is what I am running on my 434ci motor.
Tony
Old May 26, 2002 | 10:13 AM
Skelton's Avatar
Tony, what lenth pushrod did you use with the jesel and what mods to the valve cover are necessary? Thanks.
Old May 26, 2002 | 11:08 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Well, since my block deck and heads are not stock, I can't tell you what pushrod length to use. I'd imagine the pushrod length used for a stock motor is the stock length since these are designed to be bolt-in stock replacements.
The 97-98 valvecovers will not work, but you can hog out the insides of the 99+ covers to fit them. Remove those sheetmetal and plastic parts underneath and grind down any low spots, basically smooth them out underneath.
Tony
Old May 26, 2002 | 10:09 PM
felton316's Avatar
Why won't they work with 97-98 valve covers?
Old May 28, 2002 | 01:42 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by felton316:
<strong>Why won't they work with 97-98 valve covers?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Our valve cobers are different.
Old May 28, 2002 | 09:06 AM
horsepower's Avatar
SLP's 1.85 rockers are in stock and shipping -
1.85 ratio
stock appearance (basically indistinguishable unless you really focus on the location of the pushrod)
require no mods, no grinding, no new pushrods
fits 97-02 LS1, LS6, 4.8, 5.3, 6.0
NOTE: most cars will require replacement valves springs as the stock ones won't handle the increased lift.
http://www.slponline.com/view_produc...RTNUMBER=53300
- brian
