4.8 Heads...What are the pros and cons
Old May 26, 2002 | 10:49 AM
haole_boySS's Avatar
Default 4.8 Heads...What are the pros and cons
Does anyone use these heads? Do I have a chance of hitting the piston with a valve?
The reason I am asking this is because I would be putting the heads on the same time as I put in a T1 cam.
Any info from experience is greatly appreciated.
Andy
<small>[ May 26, 2002, 11:01 AM: Message edited by: haole_boySS ]</small>
Old May 26, 2002 | 10:56 AM
Fireball's Avatar
Default Re: 4.8 Heads...What are the pros and cons
Pro: small combustion chamber (same as a 5.3)
PV clearance is a function of cam size.
