HELP..Measuring pushrod length
Old May 26, 2002 | 06:22 PM
RPM Rob Z28's Avatar
Default HELP..Measuring pushrod length
Ordered new heads from AFR, and they said I would need to measure for the correct push rod length. Understand the concept, but how easy is it, and where do I get the lifter and pushrod length checker I'm told I need? Comfortable with the whole job of the head swap, just a little unsure of this part of the job.
Old May 26, 2002 | 06:29 PM
AlonzoVersion 1.0's Avatar
Default Re: HELP..Measuring pushrod length
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Rob S Z28:
<strong>Ordered new heads from AFR, and they said I would need to measure for the correct push rod length. Understand the concept, but how easy is it, and where do I get the lifter and pushrod length checker I'm told I need? Comfortable with the whole job of the head swap, just a little unsure of this part of the job.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Unless your heads are milled you can use stock length.Also I beleive thunder carrys the tools that you need.
