Want a good cam for a daily driver..........
<strong>One that will work with stock programming and makes good power from 1200-1300RPM to 6200-6300 RPM
Suggestions?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would call one of the sponsors.They will recommend you a cam within the 216-218 duration range with about a 535ish lift.Probably a comp grind.Of course you could go with the B1 Or T1 from MTI.Just give some of the sponsors a call they will take care of you.
Even the Comp 216/220 won't run quite right w/out programming. And- ANY cam is gonna run better in a LS1 w/ it.
You want the rpm band you requested? Call Comp and have 'em model a 214/220 w/ the steepest ramps they can. Get the lift #'s around .570. 114LSA. Make sure they tell ya the lobe profile grind #'s. Then call one of the sponsors and order it using the lobe grind #'s.
112 is a little peakier (won't come on for another 200rpm) and will run (barely) a little higher than 114.
<strong>
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Single pattern cams tend to idle better and have less misfires than the split patterns without sacrificing any power. You really have to listen carefully to be able to even tell the 218 cam is in there.
StevieZ, do you have a A4 or M6?
If you have a A4 and don't plan on tuning, you can get a Comp 216/216 .563 from Internet racer supply.
If you have a M6 the TR220 or MMS218 would be a good mild option but you can go bigger and still maintain diveability.
<small>[ May 26, 2002, 09:23 PM: Message edited by: Reboot ]</small>
