Is anyone running the Lunati 382 rotating assembly?
- Matt
<strong>Loking at this thing, and I was a bit curious... Wondering if anyone here was running it, and if so, how much did it cost to prep the block for the rotating assembly? Anything else someone who is considering this kit should know? Thanks!
- Matt</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I purchased the Lunati kit for my 409 iron block. The only difference between that kit and the 382 kit is the pistons. The only real machine work that may be necessary is to hone the cylinders for .002"-.003" piston to bore clearance and to align hone the mains. Other than that, it is a direct replacement for the factory assembly. Once you have the assembly in hand, bring it and the block to the machine shop, have them machine the block appropriately then measure all clearances (many times...) and assemble.
Hope this helps,
Shane
