70 LS1 overheating update
Old May 30, 2002 | 09:48 PM
70 LS1's Avatar
Conversion master
Default 70 LS1 overheating update
OK, so my car is running again. I cut the water neck and had it welded so it points staight out. This let me run a hose right down to the radiator. No more air bubble for me. I finished the compression check and reset the PCM by pulling the two PCM fuses. I started it up and it is running as smoothly as it ever did. I still need to autotap it to see what codes it is throwing, but at least it is running again. My engine is still running a little hot, but it is not overheating. I verified flow through the radiator by revving it up a little and watching the turbulence in the water. No oil in the water, thank God. I still need to seal the fans to the radiator to get more air flow through it.
My question for you guys. How hot do your heater hoses get with the heater on? Mine seem to be getting quite warm.
Old May 31, 2002 | 10:30 AM
C5 Hardtop's Avatar
Default Re: 70 LS1 overheating update
The stalling went away after a PCM reset? <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
You should get yourself a guage <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Joel
Old Jun 1, 2002 | 12:35 AM
70 LS1's Avatar
Conversion master
I have a water temp gauge, I just need to find a sender that will work with the LS1 heads. The stock 70 sender is about twice the size of the 99 LS1 one and I don't feel like drilling that much in the heads.
