pushrod length
i would like to get a cam with the specs: 216/220 112LSA +4 .561/.564. also i want a thinner head gasket of .42 rather than the stock .52. what size push rods would i need? or is this something im going to have to check when i have it assembled in the truck.
You can use your stock pushrods and be fine, but you will no longer have correct valvetrain geometry as the lifter is soaking up the discrepency of the pushrod length.
You want correct valvetrain geometry to keep the rocker tip with a perfect sweep pattern across the top of the valve stem. With a adj setup it's very simple to adjust this.
You can also use a pushrod length checker to verify.
sorry for all the questions and thanks for the help.
