Opinions on iron block 409 stroker
Sean
I whave plans to build a iron blocked 409 with the 6.0 heads(w/ a stage 2 or 3 porting) with a nice size cam(something to go good with a blower) and have a big hair drier putting out about 12-15 lbs of boost out. But that is in the future and only time will tell when that happens(hopefully soon!)
Josh S.
This is just my opinion. You must weigh the risks of resleeved blocks against the weight penalty of an iron block.
I was able to offset the weight of my iron block by using the BMR tubular K and A-arm setup and by a few other weight saving mods. I still have to accept the fact that I will always be about 100 #'s heavier than I could be.
Shane
<small>[ June 02, 2002, 10:54 PM: Message edited by: XtraCajunSS ]</small>
<strong>If you want a nearly bulletproof bottom end, the iron block is the way to go. There will be no worries about dropped sleeves or associated problems with re-sleeved blocks. It is definitely a safe choice to pour your hard earned dollars into. I went that route because I have a relatively limited budget and I am confident in the minimal risks associtated with boring an iron block .030" over. The only drawback to this setup is a 100# weight penalty.
Shane</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I thought about tubular a&k arms as well, ecpecially if I go w/ an iron block. Have you moved your battery to the rear? That would be alot of weight right there. I imagine all that would almost equal everything out.
Since you are now bolting aluminum heads to an iron block, you have less distortion of the deck surface under extreme conditions. Iron is a better clamping surface too. You can go up to 4.060 bore and avoid expensive sleeving.
But the added weight is NOTICEABLE on the front end.
I have an ARE 422ci IRON setup and after I hit my NA goal I will spray it.
John
11.1 NA at 3700 raceweight last year, goin' for 10.75 FIRST
Sean
