broke bolt off in head!! need help!
Old Jun 2, 2002 | 05:45 PM
black00WS6's Avatar
Default broke bolt off in head!! need help!
Well I put in the new TR230 cam and when I was putting the valve covers back on, I misread the torque specs and SNAP, one broke off. Anyone know how the hell to get it off?!?!? We put a couple of washers under the coil packs to hold the bolt down but I would rather get it out and put a new bolt in.
Also, it runs real rough in 6th gear. If you give it the gas, the whole car start shaking like it is missing. It might be from a loose #8 plug wire but 6th gear is the only one that it does this in. Could as well be from the stock tuning, any ideas??
Old Jun 2, 2002 | 06:14 PM
MyLS1Hauls's Avatar
Default Re: broke bolt off in head!! need help!
Use an EZ out screw extractor. Vermont American makes the reverse thread type that I like. You drill the proper sized hole and thread the extractor in. Works great. Good luck.
Brad
