anyone else have this problem with the TR230 cam??
Old Jun 2, 2002 | 08:14 PM
black00WS6's Avatar
Default anyone else have this problem with the TR230 cam??
Just installed the cam this weekend and in 6th gear, if I give it the gas, the gearshift shakes bad and the car sputters around. So far, this only happens in 6th. I do still have stock tuning, but will be using LS1edit next weekend.
I'm hoping its a loose spark plug wire.
Old Jun 2, 2002 | 10:00 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Default Re: anyone else have this problem with the TR230 cam??
At what MPH/RPM does it happen?
Old Jun 2, 2002 | 11:33 PM
VINCE's Avatar
Shorty Director
Sounds familiar.. If your rpm is below 1800rpm then I would suspect cam surge type of activity, but if this is not the case I would check your injectors.. You might be running on 7 cylinders..
Old Jun 3, 2002 | 06:22 AM
black00WS6's Avatar
It happens on any MPH/RPM range in 6th. When I get home tonight, I am checking all the plugs and wires to make sure they are tight. Then take it down the road with an a-tap hooked up.
After we got it started, it ran great, then on my way home, about a half mile from the garage, I was stopped and it was idling around 900, then all the sudden it just dropped to 500 then back up. Hopefully something just shook loose and nothing major
Old Jun 3, 2002 | 07:01 AM
Patrick G's Avatar
LS1 Tech Administrator
Mine pulls strong in any gear above 1300 rpms. I've got OD coming on around 30 mph if you can believe that. I really lug the motor down with this cam...no cam surge. The real key to getting this cam to work is drilling out the throttle blade to the proper size. You want your AIC counts in the 40s at idle in neutral. For me, a 13/64" hole worked great. You could start at 3/16" and go bigger from there. Your hole should be between 3/16" and 1/4". Mine was on the smaller side.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
