I have chocolate milk on my lifters.
I'm checking out a used engine I bought for $1200
I don't need the heads or the valvetrain off it. Mainly I'm concerned with the short block.
I took the heads off today and I found two bent and one broken PR. To my untrained eye I see no visable damage to the valves or the piston tops. I haven't cleaned them yet but, the cylinder walls and everything look fine.
I can tell that the previous owner was a racer because of the PRs.
Like I said I'm concerned with the bottom end. My oil pump went out in my TA so I'm pretty sure the heads/cam/valvetrain are good. (hopefully)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JC_1:
<strong>Can I get some suggestions on what to look for to ensure the bottom end is in good condition?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Take the oil pan off and inspect the bearings.
There's rust on the front of the crank and the oil pump.
Any suggestions? I'm gonna try and get my $$ back, the seller said he would stand behind the motor.
If the PRs are broken, I'm sure the motor has been beat to hell. Also, coolant in the oil will trash the bearings...and a rusty oil pump? Damn. Get your $$$ back.
Brad
Brad
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow:
<strong>No cracks in the block? Hydrolocked?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No I don't see any cracks in the block. The rotating assembly spins freely.
