Cam Installation: Is it necessary to remove the heads
Old Jun 3, 2002 | 07:39 AM
Jadeeglide1550's Avatar
Default Cam Installation: Is it necessary to remove the heads
I saw a reply from someone and basically the way he described changing a Cam he did not even mention removal of the heads. Fom being under my valve covers to change springs and rocker arms, I could not see how you could get the lifters off the cam so you could remove it without the removal of the heads. I am going to be changing the stock cam out in the near future, and if there is a way to change the cam without head removal, I would certainly like to know about it.
I would appreciate any comments on this.
Thanks......
Old Jun 3, 2002 | 08:06 AM
Fireball's Avatar
Default Re: Cam Installation: Is it necessary to remove the heads
read my reply here:
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=1;t=005331
