What cam would you pick for a 422??
Old Jun 3, 2002 | 01:26 PM
Colonel's Avatar
Default Re: What cam would you pick for a 422??
What kind of idle and drivability do you want? What will the C/R be? Pump gas or race fuel? What heads? What intake manifold? How high do you want to spin the engine? How much spray?
Old Jun 3, 2002 | 02:17 PM
masmith's Avatar
Idle doesn't matter it can be very choppy, some what drivable but I have a pretty expanded idea of what drivable is. 7k max and ported 6.0 heads and a holley intake port matched. CR should be around 12 and a 200 shot.
Sean
Old Jun 4, 2002 | 12:43 AM
masmith's Avatar
Default What cam would you pick for a 422??
What cam would you go with it needs to be solid roller and be great N/A and with spray.
Sean
Old Jun 4, 2002 | 04:10 PM
Colonel's Avatar
You really don't need a solid lift just to spin 7000 (not saying that there wouldn't be some advantages.) If you were to stay hydraulic I would suggest the MTI S1 cam that I use. It's 244/244 .612/.612 112 LSA. I shift at 6800-6850 with this cam. It does make great power up to 7000 RPM but I'm not really comfortable with that.
I wouldn't worry about designing the cam around the spray for only a 200 shot. That's not much for a 422 CI engine.
<small>[ June 04, 2002, 04:12 PM: Message edited by: Colonel ]</small>
Old Jun 4, 2002 | 06:44 PM
ShiznityZ28's Avatar
you should listen to the colonel his big motor runs like none other!
Old Jun 4, 2002 | 11:24 PM
Beeler422's Avatar
Back in the staging lane
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ShiznityZ28:
<strong>you should listen to the colonel his big motor runs like none other!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">agreed
Old Jun 5, 2002 | 08:14 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I've got the MTI S1 camshaft also. I also agree that for anything less than a 300 shot, build the motor for max NA performance.
Tony
Old Jun 5, 2002 | 06:43 PM
masmith's Avatar
Would the S1 be fine if I ever wanted to step up to a 300 shot?
Sean
