Difference between LS6 & LS1 heads
Old Jun 6, 2002 | 06:37 PM
BLMONGOOSE's Avatar
Default Difference between LS6 & LS1 heads
What is the difference between the ls6 and ls1 head. Can you tell by just looking at it?
A local mechanic is selling a set of stock LS6 heads but the heads look almost the same as my stock 98 heads. The only difference I can see is that the valve cover screws in differntly. But I know that the 97-98 valve covers were also changed in 99+ heads.
How can I make sure that the heads he is selling are LS6 or 99+ LS1 heads. If anyone has picture that would help allot.
Old Jun 6, 2002 | 06:56 PM
new-LS1's Avatar
Default Re: Difference between LS6 & LS1 heads
Ls6 heads have a (D)port for the exhaust, where as the LS1 have a circle exhaust port.
Old Jun 7, 2002 | 03:19 AM
AlonzoVersion 1.0's Avatar
Also I beleive the compression is higher for the ls6 heads.
Old Jun 7, 2002 | 02:25 PM
BLMONGOOSE's Avatar
What about the valves? Are they larger or the same valves as the LS1?
Old Jun 7, 2002 | 02:27 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLMONGOOSE:
<strong>What about the valves? Are they larger or the same valves as the LS1?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think the valves are bigger but I am not sure.TTT for you.
Old Jun 7, 2002 | 09:02 PM
Jason99T/A's Avatar
I can shift faster than you.
No, the valves are the same as a regular LS1 (2.00/1.55).
Old Jun 7, 2002 | 09:06 PM
Crazyquik's Avatar
You'll be able to tell from a glance by looking at the exhaust port.
O vs D
J.
Old Jun 9, 2002 | 07:32 PM
kewlbrz's Avatar
Just as additional FYI, there is a lot more to the LS6 heads than just the exhaust D port.
This will give you a full explanation:
2001
http://idavette.net/hib/ls6/INDEX.HTM
2002
http://idavette.net/hib/02ls6/index.htm
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ June 09, 2002, 07:33 PM: Message edited by: kewlbrz ]</small>
