How many 2002s are burning oil?
Old Jun 7, 2002 | 11:05 AM
Patman's Avatar
Default How many 2002s are burning oil?
I'm just curious, GM "supposedly" fixed the 2002 LS1s and LS6s to eliminate oil burning, but I still hear people from time to time complaining of oil burning with 2002s on here.
How many of you 2002 are experiencing oil burning, and how much oil are you using?
Old Jun 7, 2002 | 11:23 AM
quickWS6's Avatar
Default Re: How many 2002s are burning oil?
Mine hasn't burned a drop.
Drove her for 400 miles on the interstate, then I was like a bat outta hell from then until now. Changed oil at 450 miles, 1000 miles, and 2000 miles with Valvoline Racing 10w30. Just switched to Royal Purple 5w30 at 3000 miles.
Old Jun 7, 2002 | 01:01 PM
CRASH 02's Avatar
Mine burns just as much as my 01 did.
Old Jun 7, 2002 | 01:23 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Mine is doing great. Even with 5-10 1/4-mile passes in one night, it didn't even burn 1/4 of a quart! I used around 1/3-1/2 qt. in 1,250 miles, and that was with quite a bit of 1/4-mile passes. With regular driving on the road, it doesn't use a drop.
__________________
Old Jun 7, 2002 | 02:57 PM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Patman:
<strong>I'm just curious, GM "supposedly" fixed the 2002 LS1s and LS6s to eliminate oil burning, but I still hear people from time to time complaining of oil burning with 2002s on here.
How many of you 2002 are experiencing oil burning, and how much oil are you using?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">why were they burning oil.
Old Jun 7, 2002 | 03:56 PM
BADSS's Avatar
I don't have a 2002 (mine is a 99), but I did get the new rings put in my motor which are SUPPOSED to stop the oil consumption. The 2002's come from the factory with these rings. FWIW, my motor still burns just as much oil as it did before the rings were installed- about a quart every 500-1000 miles.
Old Jun 7, 2002 | 05:14 PM
LS1x2's Avatar
Formerly 4mulaJoe
I just saw a 2002 with 1000 miles on it 2 weeks ago with the heads off. The intake ports were covered in oil from the PCV shooting oil in there. The PCV systems ont hese cars are a joke.
Old Jun 8, 2002 | 12:30 AM
02 SOM WS6's Avatar
Not mine. At least not yet. Time will tell if running it a little harder with the new cam will affect anything. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Les
Old Jun 10, 2002 | 04:46 AM
z28fiend's Avatar
I havent burned any oil yet. I have 3300 miles on her. Changed to royal purple synthetics at 500 miles. My friends 98 Z28 burns a qrt. every 2000 miles or so. I hear that it is normal.
Old Jun 10, 2002 | 09:46 AM
AgaveCorvette's Avatar
no oil burning for me, almost 10000 miles, using 0W30 mobile 1. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 10, 2002 | 10:41 AM
Biochem's Avatar
Just changed the oil for the first time... no problems. I've heard it is attributed to the way certain drivers keep the revs high while slowing down (downshifting?). I've also heard there is less oil consumption with dino oil than with synthetics.
Old Jun 10, 2002 | 11:54 AM
C5X2C's Avatar
I am talking to a GM regional rep about oil consumption (1 qt every 2000 miles) today. I am dissappointed that GM is revising their oil consumption estimates to coincide with their engineering challenges. Has anyone heard if the new rings really fix the issue? I am not keen on replacing rings is the result is the same.
Old Jun 10, 2002 | 04:58 PM
NastySSoo's Avatar
The engine should be warm, but the engine MUST be turned off so the oil can return to the pan.
Old Jun 10, 2002 | 05:29 PM
ls1mn6's Avatar
If you are referring to the PCV problem, I think the fix is only on the LS6. The '01 and '02 camaros are the same as before.
Old Jun 10, 2002 | 05:31 PM
TravWS6's Avatar
So im guessing this is a issue with the 2001 TA's? mine is fine right now.. nopeing it won't start smoking.
Old Jun 11, 2002 | 12:27 AM
numbZ's Avatar
My `02 Z has a small oil consumption problem but it`s not due to a ring problem. It`s because of the shiznitty pcv systems on these cars.
Old Jun 11, 2002 | 12:30 AM
Blue Meanie's Avatar
Mine is starting to burn quite a lot. There are bubbles on the dipstick every time I check the oil with the car running. I just got back from checking it and the damn dipstick was smoking when I pulled it out. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I am kind of worried.
Old Jun 11, 2002 | 12:44 AM
Mike's 01WS6's Avatar
I believe it says in the manual to check the oil on a level surface with the engine OFF.
Old Jun 11, 2002 | 12:49 AM
But the motor has to be warm correct? It says operating range on the dipstick.
Old Jun 11, 2002 | 10:04 AM
C5X2C's Avatar
Talked with the GM Regional Rep about my oil consumption. I was late because my Low Oil indicator flashed on the way to the dealer and I needed a quart. At one quart of oil every 2400 miles, I have chosen to live with the issue rather than replace the oil rings.
