Piston to valve clearance: Thunder 230 cam
You should regularly shoot for a minimum of ~80 thousandths clearance on the intake valve.
The cam is on a 111 lsa, with 0 degrees of advance ground into it.
Jason
<small>[ June 07, 2002, 11:10 PM: Message edited by: Jason99T/A ]</small>
1) How much is milled of the 5.3 heads?
2) How much advance is ground in the TR224?
And just out of curiosity, if you advance a cam, doesn't the clearance diminish even more? Is that why you Thunder chose not to grind any advance in the cam?
Jantzer: The 5.3l heads were milled 15 thousandths.
Retarding the cam opens the exhaust valve earlier and the intake valve later. This give you more clearance on the intake side, and less on the exhaust side. Advancing the cam will bring the intake closer and the exhaust slightly further from the piston during the overlap period (where piston to valve clearance becomes an issue).
The TR 224/224 has 4 degrees of advance ground into it. The TR 230/224 has 0 degrees advance ground in. This was done to help top-end power, since retarding the cam moves the powerband upward.
<small>[ June 07, 2002, 11:48 PM: Message edited by: Jason99T/A ]</small>
<strong>DravenMyers: Do you know how much your heads have been milled? Normally, the 5.7l GTPs are milled 30 thousandths. This will be cutting it very close in terms of piston to valve clearance. Have your heads been finished yet? If not, just tell Craig to mill them 15 thousandths if you want to be on the safe side.
The TR 224/224 has 4 degrees of advance ground into it. The TR 230/224 has 0 degrees advance ground in. This was done to help top-end power, since retarding the cam moves the powerband upward.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jason, I bought my heads from Thunder and I already recieved them. So, I guess they are milled 30 thousandths <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> Should I just stick with the TR224 then?
Thanks,
Ahmad
<small>[ June 08, 2002, 04:57 PM: Message edited by: The Emperor Of Darkness ]</small>
As Vince said, you can either have someone notch your pistons or just use the TR224 cam. Using the 230 with that setup is going to very risky, IMHO.
The 230 cam is about the biggest I would use with the GTP stg 2 5.3l heads (milled 15 thous.)
Jason
<small>[ June 08, 2002, 11:49 PM: Message edited by: Jason99T/A ]</small>
Your car has the 5.7 heads on it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I am still surprised that everyone is not bringing up the MTI X1 cam.......It is a 230/227 .591/.571 on a 112. That is ALOT more lift than the thunder cam and it is still not having P/V clearance issues.......
Also, as far as I know, I haven't seen anyone post the X1 cam's clearance with a set of stock/ported heads. Until we do so, you will never know how much clearance there really is. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ June 09, 2002, 03:43 PM: Message edited by: Jason99T/A ]</small>
I'm getting ready to put a bottle on it(NX GM EFI)no more than 100LB shot and was thinking about doing a cam swap from the TR 224/224 112LSA to the TR 230/224 111LSA cam. Am I going to run into any P to V clearance issues? I was also thinking while ordering the cam to have TR grind in 4 degrees of advance. Will I have any problems other than a choppey idle? TIA,
Mark
The reason I ask, is that my car is currently down and I am going to be running a custom cam that is very similar to the X1. I know that it is going to be very close P/V clearance wise.....
Comp Cam 230/226 .592/.570 on a 112 w/ 2 degrees advance ground in......
The intake lobe will be on the Comp XER lobe, and the exhaust on a slightly less agressive lobe.
My heads have been milled .030 and I am also running 2.055/1.60 valves. I would imagine that it SHOULD clear, but I am gonna have to play with it during assembly <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Mark,
You should not have any P/V clearance issues to speak of with the Thunder 230/224 cam, but the extra 4 degrees of advance you speak of has not been tested........If you can wait about 3 weeks or so we shold have some results back on that F1 cam that I am gonna be trying out <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ June 09, 2002, 04:52 PM: Message edited by: GS WS6 ]</small>
I may have to put it all off for a while now.This evening I went up to see if the Denton 1/8 mile was finished and on the way home I think my rear end went **** up. Actaully I think it broke a bearing or the ring gear, hopefully not one of those new Moser axles I've got in there. I'm gonna have to call your Hurst shop and see If I can get it in there tomorrow and have them take a look at it. Whats the name of the gear guy over there? TIA,
Mark
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Would stock (unmilled) 5.7L heads have the same P to V clearance as stock, unmilled, with same size valves, 5.3L heads?
If so how did the clearance go from 155 thou to 80 thou by only cutting off 15 thou?
Is the height (or depth) of the chamber shorter stock on the 5.3 heads than the 5.7?
I am curious because I am running 6.0L heads that have been decked 0.030 and want to know if mine would clear or need reliefs for this cam.
Speed Demon: Yes, the clearance would be the same if you put 2.00/1.55 valves in an unmilled 5.3l head.
Taking 15 thousandths off the deck of the head does not mean you loose exactly 15 thousandths clearance. Everything is at an angle, so you would have to use some trigonometry (set up a triangle, etc). Also, going to larger valves reduced the clearance as well.
<small>[ June 10, 2002, 10:50 AM: Message edited by: Jason99T/A ]</small>
