Stroker Poll
Old Jun 10, 2002 | 10:28 AM
CHRISPY's Avatar
Default Stroker Poll
Hi guys,
What size stroke crank are you running.
What Bore size...
What is the largest stroke crank you have seen used?
Cheers,
Chris
Old Jun 10, 2002 | 11:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Stroker Poll
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>Hi guys,
What Bore size...
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">4.075 stroke = Lunati 4.000 stroke offset ground
4.060 bore = 6.0 LQ4 block
4.125 = most stroke I have heard, after a while too much is too much.
Old Jun 10, 2002 | 11:39 AM
Warbird's Avatar
<strong>Hi guys,
What Bore size...
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a 4.060" Bore, 4.00" stroke = 415 CID
The biggest motor I have seen is 4.125 Bore, 4.125 Stroke. I agree with PSJ you do get to the point of diminishing returns aound 434/6 max even at this size you are beginning to push the limits of reliability and block integrity of the aluminum block.
Paul
Old Jun 10, 2002 | 05:36 PM
XLR8NSS's Avatar
Adkoonerstrator
I'll be running a 4.03" bore and 4.125" stroke.
There may be some awesome heads out within the next year or two from AFR. With a custom intake and these heads I think these strokers will be able to be twisted up pretty high.
I was thinking of going with a longer stroke but, decided to wait and see what type of heads and intakes develop. If I ever want to upgrade this motor, that I don't even have yet <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> , then I'll go with new heads, intake, and throw a solid roller in there so it can be spun a little harder. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I'd be scared of putting too big a stroke in for fear of a rod hanging out the side of the block. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I think in the next year or two we're going to see some serious N/A LS1's, especially with new head development. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
John <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 10, 2002 | 07:07 PM
strife's Avatar
4.125
What Bore size...
4.1
I have seen mention of a 4.25 crank on this forum
Old Jun 11, 2002 | 09:14 AM
MattG's Avatar
I have a Lunati 4.125" crank, with a 4.1" bore resleeved ARE LS1 block. As for the largest, Walker from the Corvetteforum had MTI build him a 449ci, which is a 4.250" stroke and 4.100" bore I believe.
Personally I love the extra stroke to give you the low rpm torque that sets you back in your seat real hard all the way from 2000rpm to 6800rpm.
Old Jun 11, 2002 | 11:04 AM
kewlbrz's Avatar
Someone on corvetteforum.com a while back had a 454ci LS1. I want to say ARE built it.
Old Jun 11, 2002 | 11:13 AM
XtraCajunSS's Avatar
Yes, the longest stoke crank offered for the LS1 is 4.25". I don't believe anything longer would clear the skirt of the block. Theoretically with a C5-R block you could build a 462 cu in engine (4.160" bore X 4.25 stroke)
My stats are 4.030" bore (iron block) with 4.00" stroke.
Shane
