Rocker Arm Choices?
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>when feasible...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">exactly.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It would be feasible for anyone to do. It would be feasible for me to do it since I broke a rocker arm with a completely stock engine. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I just can't afford them now.
why an adj. set up on a hyd cam, terry?
and
im thinking a stock rocker is less than an 800 dollar set of non-adj. jesels. not feasible in my mind any time. so why switch?
two questions.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I want a better rocker for high RPM use, and if I'm spending the $800 I want something I can use with a solid roller down the line.
and
http://ls1.fbody.com/car/mods/heads/day2/IMAGE010.jpg
There are several mods that need to be made to the head casting to fit the T&Ds. Im sure MMS knows exactly what those are. Im sure they also know the issue with large spring seats and ported LS6 castings. So no doubt all is fine.
I'll be using fully adjustable Jesels on my big-bore.
\chris
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">MMS has never used the T&D's before, so this will be a first. I'm assuming you just test fit the rockers and grind away wherever they hit. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
The only modifications necessary on my heads were the spring pockets for the 1.550" springs. The T&D's required no machine work on their own. They come with a small template and a set of shims to achieve proper rocker arm geometry. Depending on your valve stem length and installed height, you may need to shim the pedastals or have T&D make you a custom set (they did this for me.) Other than that, you will most likely need a custom length pushrod.
Shane
