Cam gasket kit.
Old Feb 10, 2007 | 04:04 PM
MavrikTA's Avatar
Default Cam gasket kit.
How many of you are purchasing a complete "cam replacement" gasket set? Im about to order a cam and was wondering if all I really need is the crank bolt? Thanx.
Old Feb 10, 2007 | 04:19 PM
NviouSS's Avatar
the stock crank bolt is only good for 1 use. i ordered my kit from tsp and thiers comes with all the gaskets and new crank bolt.
Old Feb 10, 2007 | 04:32 PM
V6 Bird's Avatar
Oreillys has a kit similar but it doesnt have the crank bolt. Those are like 5 bucks. The kit is 23 bucks.
Old Feb 10, 2007 | 04:33 PM
MavrikTA's Avatar
Yeah, I know I need the crank bolt, but are all the other gaskets in the kit necessary(i.e. stock gaskets reuseable), or should I just buy the bolt?
Old Feb 10, 2007 | 04:40 PM
NviouSS's Avatar
depends on what condition they are. when i swapped cams 2 years ago my car had around 24k miles and the water pump gaskets were falling apart. if they appear to be in good shape then reuse them and just buy the bolt.
Old Feb 10, 2007 | 04:48 PM
MavrikTA's Avatar
Ok. Yeah I figure that I can run to the auto parts store and get gaskets on a case by case basis if necessary, I just cant imagine what is included with these $80 gasket kits companys sell with cams?
Old Feb 10, 2007 | 04:52 PM
NviouSS's Avatar
Basic Camshaft Bolt & Gasket Kit
Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets & GM Harmonic Balancer Bolt. Everything you need for a basic camshaft swap!
taken from tsp's site. should be around $55 after shipping.
Old Feb 10, 2007 | 05:04 PM
Blk97WS6's Avatar
i would definetly replace all of them if your car has a decent amount of milage on it. id hate to have to pull it apart again just because a damn gasket is leaking.
Old Feb 10, 2007 | 05:13 PM
MavrikTA's Avatar
Im at like 48K I think. No leaks.
Old Feb 10, 2007 | 05:53 PM
Blk97WS6's Avatar
id replace them all, except maybe the valve cover gaskets. those can be re-used if you wish.
