Cylinder Heads Question
http://texas-speed.com/shop/item.asp...d=649&catid=20
I am looking at these beacause they are only $1300 for stage 3 ls6 and $1100 for the CNC ported heads. I dont know a damn thing about heads all I know is I need to rebuild my valvetrain and I was looking at these.
Any recomendations?
http://www.lmperformance.com/5091/1.html
what else would you suggest?
they are less than $950 without the cnc valve job fully assembled with new stock size valves but not hollow valves and sodium filled exhaust valves with LS6 springs (still cnc ported intake and exhaust)
plus $100 for the cnc valve job (here is where they become $1050)
then there is the spring option where the price will reach the $1300 you posted with the PRC dual spring kit with the titanium retainers ...
they are all stage 1 .... (see below item detail at the top the name and item #)
now if you want to upgrade your valvetrain they have a great cam package ....
if you want heads and cam they also have a heads and cam package (big money saving there)
they have a stage 2.5 ls6 heads .... with dual valvesprings kit and bigger valves 2.02 or 2.04 intake vlaves your choice and 1.57 exhaust valves for $1450
http://texas-speed.com/shop/item.asp...d=134&catid=40
and a stage 3 ls6 heads with even bigger valves but for bigger Bore engines (LS2 or Iron Block that come with 4.000 Bore) 2.08 intake valves and 1.60 exhaust valves with the dual valvesprings.
$1850
http://texas-speed.com/shop/item.asp...d=688&catid=40
hope it clears things up ....
but a recommendation will depend your cam choice and if you're willing to flycut the pistons for the bigger valves with big cams or high lift cams with milled heads.
$1850
