Milling 241s
Old Feb 11, 2007 | 04:42 PM
pist0lpete's Avatar
Default Milling 241s
I am building up my 2002 LS1 with forged pistons and fully balanced rotating assembly and unfortunately the -4cc valve reliefs in my mahle pistons is killing my SCR and DCR. Looks like unmilled my DCR is somewhere in the low 7 range. If I mill my 241s down to somewhere near a 60cc combustion chamber which would require about .050 milled off (assuming .050 as the limit for intake fitment reasons). That should get my DCR into the 8.2 range. Will I be giving up too much in the way of head flow by doing this? I would like to find a set of 243s for cheap but it very well may not be in the budget. If I was to get a set of bare 243s can I just transfer my valves from my 241s (18,000 miles on the 241 heads) onto the 243s along with my dual valve springs? For inquiring minds my cam is a 228r (228/228 .588/.588 on a 112+2).
Old Feb 12, 2007 | 12:38 AM
pist0lpete's Avatar
Anyone with any theories?
Old Feb 12, 2007 | 06:15 PM
pist0lpete's Avatar
Does anybody here know anything about building their own engines?
Old Feb 12, 2007 | 06:43 PM
cws T/A's Avatar
You can swap the valves from 241's to 243's
I get 7.63:1 dcr / 9.85:1 scr with 67cc .052
8.26:1 dcr / 10.7:1 scr 60cc .052
8.50:1 dcr / 11.0:1 scr 60cc .040
Thats using a calculator that reads high ..it figures 10.3:1 for stock ls1
Old Feb 12, 2007 | 07:46 PM
SMKDFRD's Avatar
yea, what he said
Old Feb 12, 2007 | 10:11 PM
pist0lpete's Avatar
Well those are similar to the numbers I calculated but I just gave rough ones becuase I didn't want to redo it. However, does anybody have any idea how this will affect head flow?
