Beware of new GM multilayer head gaskets!!!
I just found out the hard way. Had the engine out after several problems(blown head gaskets,crank pulley spinning,broken piston ring lands, and rod bearings being beat up) I pulled the engine and completely disassembled. Had a keyway cut in the crank. Installed new main bearings. Installed hardened rod bearings. Installed Kaytech stronger rod bolts. Installed ARP head studs and used the new multilayer head gaskets. reassembled the engine and reinstalled in the car. Once every thing was hooked up, filled up the cooling system. After about a minute I started seeing drips of coolant on the ground. There was coolant coming from both heads. Installed cooling system pressure tester. Pressurized the system and found both head gaskets leaking. Removed the engine again. Removed the heads. Found the heads have a notch cut in them on the lower edge towards the front of the head. The new head gaskets don't seal that area so coolant just has a free path to come out. It was leaking coolant and I didn't even start the car yet..
I would assume the 2002 heads don't have that notch.
So beware of using those gaskets on anything other than an 02.
<small>[ April 09, 2002, 10:21 AM: Message edited by: Pro Stock John ]</small>
That would seem more likely, your car is a 2000 right? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
The heads havent't changed from a deck surface perspective. There must be something up with your heads.
Infact, i've got my stock 2000 heads here to take pictures of.
and what heads are they?
Brad
<strong>Installed hardened rod bearings.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What is THAT???
I'm not aware of those... Please enlighten.
SC
There was no machine work done on any of the heads.
The hardened rod bearings are clevite performance bearings. They are supposed to help resist the damage to the bearing half in the rod. I think they are heat treated.
I have pictures if somebody can host them for me.
BTW, I will buy those tripple gaskets from you if you don't want them.
Also this was on all different model years.....Sounds like something else is going on in your case.
Brad
Head gasket pic 1 shows both head gaskets. In head gasket pic 2 I flip the lower gasket over.
You can see that it says front on both sides of the head gasket. There is no left and right one.
If you look at the notch in the head and at the raised rubber part of the head gasket, you will see that the notch is wider than the rubber of the gasket.
There is no notch in my 2000 heads
http://harlan.sketchy.net/teardown/107-0715_IMG.JPG
and the 6.0L gaskets look the same
http://harlan.sketchy.net/gaskets/
<small>[ April 09, 2002, 07:05 AM: Message edited by: HOWQUICK ]</small>
