Beware of new GM multilayer head gaskets!!!
Looks like I have the notch:
http://www.jaxracing.com/lswon/teardown/Mar23_06.JPG
<small>[ April 09, 2002, 08:15 AM: Message edited by: Jax White TA ]</small>
I cut it for a keyway and it's fully keyed now to the ATI damper. I even firmly soldered the key into the crank to make it as rigid as possible.
My heads have that notch also.I almost went with the MLS gaskets But I found some graphites locally in stock. Never had a problem with a head gasket after tons of Nitrous use and later 10psi boost. Managed to break a piston before hurting a gasket.
IMO the graphite gaskets are pretty stout and seal very well.
<small>[ April 09, 2002, 10:32 PM: Message edited by: AzzHauler ]</small>
I have 4 sets of heads. All 4 sets have notches. Three sets are from 99's. one is from a 2000.
I had parts check the part #'s. They show the same head from 99-02. But the new gasket for only 02. He called GM engineering. They said they have not changed the heads since 99. We had a new head in stock for a 99-02. We opened it. It did not have the notch. So I guess sometime in 2000 is when they changed it. So I guess if you don't have hte notch you can use the gaskets. I'm going to have the notch filled by a machine shop and use the new head gaskets.
<img src="http://www.jaxracing.com/lswon/notch.jpg" alt="" />
<strong>Do the 6.0L heads have this notch?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">mine don't <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>
Installed hardened rod bearings.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where do you get hardend rod bearings from? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.sigma-epsilon.org/steve/images/performance/headcam/day3/MVC-135S.JPG" alt=" - " />
Wierd....
