PianoProdigy DCR calculator-I'm screwing this up obviously
Old 02-12-2007, 01:48 PM
frodo84's Avatar
Default PianoProdigy DCR calculator-I'm screwing this up obviously
Here is the cam card and I'm trying to manually input the data for my futral f-15 and new 383 shortblock...my pistons are .010 out of the hole btw....
EDIT: Okay, I think I have it right now....
Old 02-12-2007, 02:21 PM
silverbandit0996's Avatar
i wish i had Excel
Old 02-12-2007, 02:33 PM
Thimble's Avatar
Your .006" and .200" durations are way off. Where did you get those values from?
Also, your deck on the spreadsheet is showing .005", not the .015" you stated.
Old 02-12-2007, 02:38 PM
frodo84's Avatar
Default thanks
You're right, I corrected the deck height. My cam card doesn't have the .006 and I used this formula for the .006 value:
Advertised duration divided by 2, plus your ICL, minus 180.
Looking at it now, the .2 value is way off, I can extrpolate a number for it, how is the correct way to determine this value, if not from the cam card?
Old 02-12-2007, 10:30 PM
frodo84's Avatar
top....
Old 02-13-2007, 12:48 AM
pist0lpete's Avatar
Usually adding 49 or 50 to the value at .050 will get you there or really close to the the lift value at .006.
Old 02-13-2007, 11:06 AM
frodo84's Avatar
okay, I got my .006 and .200 numbers right, still looks high, opinions?
Old 02-13-2007, 01:21 PM
HEMIETR's Avatar
How did you obtain those numbers if not on the cam card? I have the same issue.
Old 02-13-2007, 02:00 PM
frodo84's Avatar
I called Futral Motorsports and got the durations required....it looks like I'm going to have to relieve the pistons a little to increase chamber volume to get where I want to go....~8.5 DCR.
