Degrees to grind into cam?
Old Jun 21, 2002 | 03:03 AM
AlonzoVersion 1.0's Avatar
Default Degrees to grind into cam?
I will get it with a 114 lsa and my car has a TP 4000 with 3.73's and I shift at 6600.Thanks.
Old Jun 21, 2002 | 07:51 PM
VAP's Avatar
VAP
Default Re: Degrees to grind into cam?
Don't know what cam your talking about ,but recently was doing some engine dyno development on a LS1 with a cam of 114 lobe sep. With a adjustable vernier type timing set and found once we moved the cam around in several positions that 111 intake centreline works best which is 3 deg advanced. It was worth a genuine 9hp from about 4800 rpm onwards with no torque loss. Would never sacrfice torque down low for hp up top. Note that every cam profile is different though and not so sure that this would be the case in your application but thats what we found - All the best <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 22, 2002 | 05:46 AM
My cam selection will be a 224/224 duration with .600/.600 lift.Thanks for the help.What would you recommend with this cam.
Old Jun 22, 2002 | 11:04 AM
MyLS1Hauls's Avatar
FWIW, I believe GM recommends the Hot Cam be installed at 111* ICL, but its on a 112LSA.
Brad
