CAM 2 (110 octane) safe??? ASAP
Old Jun 21, 2002 | 06:39 PM
98 Smokin LS1's Avatar
Default CAM 2 (110 octane) safe??? ASAP
i was wondering if i could use CAM 2 in my car my local gas station has cam 2 there and it is 110 octane, i was wondering if i could use that for big races or will it fuct up my motor. I would only use it when i race with is not often, but my friend and me raced the other night and i only beat him by 3 cars and he has a honda but he has 7 g's in the motor and tranny. i just want to smoke him even more. so i want to use this to,.
Old Jun 21, 2002 | 08:43 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: CAM 2 (110 octane) safe??? ASAP
Dunno what your engine setup is, but any octane over what your engine needs is wasted. More octane does not necessarily = more HP.
Old Jun 22, 2002 | 10:49 AM
gator's 99TA's Avatar
first you only need high octane if you motor is built up and requires it. second, cam 2 is i believe leaded fuel which will put a hurt on your oxygen sensors!
Old Jun 22, 2002 | 02:09 PM
i have o2 simms
Old Jun 22, 2002 | 02:39 PM
RyanJ's Avatar
SSU Moderator
i surely doubt you have O2 simms up front.
Old Jun 22, 2002 | 03:03 PM
Scalpel's Avatar
CAM2 will destroy your O2s thus rendering your pre-cat O2's from delivering the proper amount of fuel to your engine.
Old Jun 22, 2002 | 04:58 PM
NastySSoo's Avatar
I have CamII at a station by my house. Both the 100 and 110 octane are unleaded. So they wont hurt your o2s. But , as someone else said unless your motor requires more octane its a waste of money or can even slow your car down. Higher octane, slower burn. I raised my compression a tad so when I go to the track in this hot Fl weather, I mix in 100 gt 50/50. Look at the pump, it will tell you if its unleaded or not.
Old Jun 23, 2002 | 11:41 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Leaded gas will lacquer up the front 02's and screw them up I only ran 5 gallons and they crapped out.
If I were to spray a 150 shot in my car I would run 104 or more octane to be safe.
