New cam in, question.....
Old Jun 25, 2002 | 11:10 AM
6-SpeedZ's Avatar
Default New cam in, question.....
My car wants to die once in a while. It needs more air, but, I dont want the RPM at idle to go up any. (I like the lope) <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Will drilling out the throttle body hole larger also increase idle RPM??
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Jun 25, 2002 | 02:54 PM
AlonzoVersion 1.0's Avatar
Default Re: New cam in, question.....
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 6-SpeedZ:
<strong>My car wants to die once in a while. It needs more air, but, I dont want the RPM at idle to go up any. (I like the lope) <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Will drilling out the throttle body hole larger also increase idle RPM??
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Drilling out the hole will make your car idle better and I would raise the idle so it wouldnt die or as much anyways but thats just me.
Old Jun 25, 2002 | 04:09 PM
6-SpeedZ's Avatar
I know it will make it idle better, but I am wondering if it actually raises the RPM. Im assuming it must.
Old Jun 25, 2002 | 04:18 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
In my experience, drilling out the hole has NOT caused any increase in idle speed.
Old Jun 25, 2002 | 04:39 PM
6-SpeedZ's Avatar
Sweeeeeet.... <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
One more question.
What is the stock hole size ?
<small>[ June 25, 2002, 04:43 PM: Message edited by: 6-SpeedZ ]</small>
Old Jun 25, 2002 | 04:46 PM
Andy West's Avatar
Did you reprogram your PCM for the new cam? That should help.
Also try removing the HPP3 programing. It may be worth a try. You could always put it back in a matter of minutes.
Good Luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 25, 2002 | 05:40 PM
Dave Carney's Avatar
I'll say the exact opposite based on my experience, drilling it out WILL increase your idle speed.
Old Jun 25, 2002 | 08:44 PM
Jantzer98SS's Avatar
I'll say from my experience that it "should" increase your idle speed a little and definately will smooth the idle out. Drill only a small amount at a time, because you'll hate it if you go too big and the car drives itself down the street at 2200rpm's. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 25, 2002 | 08:49 PM
Sears's Avatar
!Dial-up Director
Drilling out the hole in the throttle body blade will smooth out the idle. It keeps the IAC motor pintle from trying to compenstate but never really "catching up".
Justin
Old Jun 26, 2002 | 07:40 AM
RPM WS6's Avatar
Going from whatever the stock hole size is, to 13/64 (in my case) did NOT increase idle speed whatsoever as observed on a-tap. Just my experience. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 26, 2002 | 08:57 AM
6-SpeedZ's Avatar
Wow, lots of different opinions here. I am going to have to do it for sure either way, the car starts REALLY hard when hot. So, does anyone know the stock hole size in the throttle body blade so I can go get the appropriate drill bits ? TIA.
