MMS S2/224 Dyno..
Old Jun 26, 2002 | 07:33 PM
1BLKSS's Avatar
Default MMS S2/224 Dyno..
Anyone who may have followed along were probably waiting for this post. I put the car up again and this time around, the MACs were replaced with LTs and the Flowmaster catback for the Mufflex. *I need someones assistance to upload this dyno sheet* I dont know too much about how to do it so maybe I can email it to someone? Anyway, 360 hp and 350 tq! Not pleased, again!! If anyone remembers, the MACs with Flowmaster catback gave 380 rwhp and 360 tq. I understood this deal was supposed to easily generate over 400 to the wheels. The only things left to upgrade are the stock flywheel and clutch and UD pulley (pulley not worth it to me). The MAF is by GMS. The car is a M6 and has a 3.73 rear. Someone please slap me and call me Tina cuz it seems like this dyno info is not that of S2 and 224 cam--or is it me? Much thanks to all who've given input along the way! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 26, 2002 | 07:43 PM
VINCE's Avatar
Shorty Director
Default Re: MMS S2/224 Dyno..
I feel your pain.. That is a big loss. You would expect a gain.. It could be tuning?
Old Jun 26, 2002 | 09:11 PM
Jantzer98SS's Avatar
The exaust is hurting you also. Get a cutout and get it on the dyno with a wideband to check your A/F.
Remember that the numbers you see here are usually dialed in packages. And often it takes time on the dyno to get everything worked out for your car.
How much KR were you getting, timing?
Old Jun 26, 2002 | 09:37 PM
Country Boy's Avatar
Senior Member
I would hope to say tuning? Im making 350 HP and 360 TQ and I havent touched the insides. Thats with just a couple bolt ons <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Let us know what happened.
Old Jun 26, 2002 | 09:43 PM
another mitch's Avatar
I just got my initial dyno numbers today for my 2001 vette.I'm running the stageIIx truck heads with the same cam,pully,aluminum flywheel.My exhaust consists of tpis long tubes an x-pipe and A B&B catback and still using cats.
My numbers were 402hp and 379tq and it still needs a little tweaking.The mechanic say's 410-415 should be easy to get.I'm at 6000'above sea level and the numbers are corrected but the air is still thin and the dyno run was in the heat of the day.
There has to be something else wrong besides the exhaust.Was the cam degreed properly? How about knock retard?
You should definatly make more power than that.I hope you get it sorted out soon.Best of luck.
mitch
Old Jun 26, 2002 | 09:57 PM
ShiznityZ28's Avatar
i am no expert but i was told gms maf is not good for a heads and cam package. you need to get a cut out and definatly wideband also atap it. there's got to be somthin screwy there.
Old Jun 27, 2002 | 01:20 AM
Terry Burger's Avatar
I run the GMAF. I need to see the AF ratio and timing curve. Did you autotap on the dyno? Was it a dynojet?
Old Jun 27, 2002 | 06:39 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
<strong>I run the GMAF. I need to see the AF ratio and timing curve. Did you autotap on the dyno? Was it a dynojet?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i have just seen some gms mafs make you lose power when hoping up horse power significantly. it wouldn't be to hard to borrow someones stock(descreened) maf to see. A/F is a must to figure this out.
<small>[ June 27, 2002, 06:40 AM: Message edited by: ShiznityZ28 ]</small>
Old Jun 27, 2002 | 08:43 AM
Nine Ball's Avatar
LS1Tech Co-Founder
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Remember that the numbers you see here are usually dialed in packages.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
The MMS spokesperson on this site is always talking about his "off the shelf" setup and how it isn't anything special. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 27, 2002 | 10:36 AM
I wonder how many shelves those heads have been on. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jun 27, 2002 | 10:39 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Whats the shelf-life of them? Born on date?
To the originator of this thread, Flowmaster mufflers have been known to suck and sometimes cause HP losses on higher hp cars. Just FYI.
Tony
Old Jun 27, 2002 | 11:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I agree.
I love the sound of Flowmaster stuff on my rides but only the truck will get one.
Do you have the Mufflex with the Spintech or Flow muffler?
In either case I would get a cutout for dynoing.
Need to check your AF you might be pig rich.
Terry help the guy more!
Old Jun 27, 2002 | 11:43 AM
CHRISPY's Avatar
Why did you get rid of the MACs? They were definitely not your problem.
Are you running the 4 inch mufflex with flomaster muffler?
The problem is likely in the tuning...even stock heads with the 224 cam would make more power.
Chris
Old Jun 27, 2002 | 01:05 PM
9T9BlueTA's Avatar
E-mail me your Dyno sheet and I will host it for you.
Old Jun 27, 2002 | 03:08 PM
jmX's Avatar
jmX
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1BLKSS:
<strong>The header swap is controversial. Would the longer, smother collectors really provide any more hp or tq? At this time--its yet to be seen. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yet to be seen? Uh..no..tons of people have swapped from macs to FLPs/grots/whatever, and for the most part, you just gain loads of lowend power. I myself gained 0rwhp at peak, and 35rwtq in the midranges going from macs to FLP's.
The macs are fine for topend power.
Old Jun 27, 2002 | 04:12 PM
ONEBADWS6's Avatar
GO with 31 deg total timing, Get your air fuel around 12.3. It worked the best for me, believe it or not Ed Wright's mail order program was right on. I have macs with a random tech cat back and a cut out. This set up should get you 390-410rwhp with stock heads. Other wise get that cam degreed.
Old Jun 28, 2002 | 12:01 AM
1BLKSS's Avatar
The header swap is controversial. Would the longer, smother collectors really provide any more hp or tq? At this time--its yet to be seen. The Mufflex system uses the Spin Tech muffler with ORP. Like I mentioned, I'd like to upload the dyno graph but I dont know how. I could email it to someone? Again, I am pending another dyno session in another week. This time around, I'll gather as much info as possible.
Old Jun 28, 2002 | 12:21 AM
LS1Tech Co-Founder
I'd:
-Run a cutout before the catback and see if you pick up a lot, I am curious.
-Use a wideband, 12.5:1---12.8:1 AF is perfect.
-Go for 25-28 degrees of timing.
-Long tubes help for sure, won't hurt at all.
Old Jun 28, 2002 | 12:30 AM
mjf454's Avatar
I picked up 14rwhp over my 3.5" mufflex by installing a 3" cut out on each side of the y pipe.I remove six nuts at the track and get 14 hp. Did mike tune your car on the dyno? Could make a differance over mail order tunning. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Jun 28, 2002 | 12:54 AM
Jason99T/A's Avatar
I can shift faster than you.
I went from 427rwhp to 442 rwhp with the addition of a 3.5" cutout on my 3.5" Mufflex w/ the spintech muffler.
I would look into the tuning first. Then, go from there.
