Oil burning 408 help....
Old Feb 23, 2007 | 12:14 PM
  #41
oange ss's Avatar
i guess i'm still leaning toward a guide problem then...
Old Feb 23, 2007 | 12:31 PM
  #42
thunder550's Avatar
High on diesel fumes
Yeah I really need to get bank 1 seals replaced. If I swap those and still have a problem I'm out of ideas other than an issue with the heads themselves. PCV system is gone now and I'm still getting lots of smoke after it idles for a minute or two, so I think that wasn't the problem.
Anyway, if the bank 1 seals don't fix it I'm gonna see if TSP will exchange the heads for me.
Old Feb 23, 2007 | 01:33 PM
  #43
98Z28CobraKiller's Avatar
Restricted User
keep us posted.
Old Feb 23, 2007 | 01:47 PM
  #44
Jon5212's Avatar
Originally Posted by thunder550
My second ring is not gapless, only top.
I can't just take the motor back. I had a machinist build the shortblock, but I did final assembly on heads and everything else. I called him and asked, and he said he couldn't see the pistons and rings being a problem.
My bad, was under the impression you had someone put the entire thing together. Hope you get everything straightened out.
Old Feb 23, 2007 | 02:37 PM
  #45
thunder550's Avatar
Thanks, me too
Old Mar 1, 2007 | 11:45 AM
  #46
Restricted User
I have a question with regards to this problem. Would excessive back pressure from a restrictive exhaust cause increased crank case pressure?
Old Mar 1, 2007 | 12:19 PM
  #47
LostCauseZ06's Avatar
shouldnt have anything to do with it.. the pressures from a restricted exhaust is nothing compared to the pressures your rings see when they are on the compression stroke. if compression test checks out then your probably not pushing pressure into the crankcase.
if the PCV is deleted you will no longer have positive crankcrase ventilation though... the pressure will push itself out of the breathers as it builds up.
Old Dec 11, 2014 | 08:09 PM
  #48
lq4240sx's Avatar
Did you ever figure this issue out I'm having the same problem with my 408 setup
Old Dec 12, 2014 | 02:41 PM
  #49
slow ride 02's Avatar
I sure hope they did, as that was almost 7 years ago!....lol
Old Dec 15, 2014 | 01:45 PM
  #50
lq4240sx's Avatar
I dont care if it was 15 years ago. I'm having the same issue on my setup and cant figure out where the oil is coming from or why.
