Installed Tr 230 Cam, Lopes great but...
Old 06-27-2002, 10:57 PM
2000 ws6's Avatar
Default Installed Tr 230 Cam, Lopes great but...
At part throttle cruising the car stutters, like a bad misfire. I don't think it's surging but it stutters however when I give it full throttle it goes away and runs perfectly fine.
At WOT the car doesn’t stutter only at part throttle does it occur. Please help. Thanks
Alex <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
PS: No codes or DTCs set.
<small>[ June 27, 2002, 11:15 PM: Message edited by: 2000 ws6 ]</small>
Old 06-28-2002, 12:50 AM
Shorty Director
VINCE's Avatar
Default Re: Installed Tr 230 Cam, Lopes great but...
That is weird.. I would check all the injector connections to make sure they are tight.. Also plug wires..
Old 06-28-2002, 01:42 AM
I can shift faster than you.
Jason99T/A's Avatar
What rpm is this stuttering occuring? Also, what gear?
Old 06-28-2002, 09:04 AM
zGhost's Avatar
I just got mine installed last night and am somewhat getting the same effect. I have no tuning and NO headers yet, I have a catback, maf, Lid and the cam... My car does not feel all that strong either...
at WOT the car pulls smooth, but does not feel a SOTP difference from my stock cam...
i had a few engine codes, but they went away?!?!?! also the car seems to be running real rich.
Old 06-28-2002, 09:05 AM
Smoke_ur_5.0's Avatar
Check your o2 sensor readings, lterms via autotap really close and check for anything unusual. One of them might be going bad on you. I know of a car that had a similar problem and it missed around 2500rpm and then quit around 3000rpm. It was a bad o2.
Old 06-28-2002, 09:46 AM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
I think youll find it from running rich. Probably fouling out plugs.
Old 06-28-2002, 09:48 AM
2000 ws6's Avatar
It does it in every gear from 1500 rpms up to 3K than after that it gets smoother....
Old 06-28-2002, 10:29 AM
Jason99T/A's Avatar
ZGhost: Get a set of headers on your car and some tuning and the car will pick up a TON!!
2000 WS6: I would defintely look into autotapping your car to see what the Ltrims/O2s are doing, just as Mark said. Make sure the passenger side 02 sensor harness is not resting on the header tube. Just do a quick visual inspection of the engine compartment to make sure nothing is loose or out of the ordinary.
Jason
Old 06-28-2002, 10:38 AM
zGhost's Avatar
I hope that is the case, i have not dynoed the car.... I would still think there would be about a 30HP gain w/o headers but i may be wrong.... in any case, the headers are on order, just waiting...
Old 06-28-2002, 09:00 PM
Shorty Director
VINCE's Avatar
You need headers... You do have a weird situation..
Old 07-01-2002, 04:22 PM
2000 ws6's Avatar
What ever was the culprit, it has vanished and the car runs great now. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Pulls exceptionally hard especially since I have no tuning. I can't wait to get it tuned right and get it to the track <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
TR 230 = F-cking Awesome <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
