SLP Double Roller Timing Chain
Old Jun 28, 2002 | 07:19 AM
TransAmaniac's Avatar
Default SLP Double Roller Timing Chain
Has anyone installed one of these yet?
I'm hearing something about having to remove some kind of sensor on OBDII cars.
I ordered mine yesterday.
Old Jun 28, 2002 | 08:48 AM
The Emperor Of Darkness's Avatar
Default Re: SLP Double Roller Timing Chain
I may order one as well. I already ordered the katek chain but not sure I am going with the double chain with gears.....
TTT for ya
Old Jun 28, 2002 | 10:29 AM
thebadbat's Avatar
How noisy are the gears with this setup???
Thanks,
TJ <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jun 28, 2002 | 10:46 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by thebadbat:
<strong>How noisy are the gears with this setup???
Thanks,
TJ <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I read a post on LS1.Com that say's it's actually quiter than stock
Old Jun 28, 2002 | 11:58 AM
SSINFUL's Avatar
Hard to hear *anything* over the LM, but I'd say it's not noticeable in and of itself. There really can't be any increase in timing gear noise, or the knock sensors would be trying to retard alla time (mine are "desensitized anyways...)
BTW, there's only one double-roller, even what SLP sells. It's made by Rollmaster.
No sensor removal. Ya do haveta shim the oil pump (maybe .060) to make it past the double-wide gears. Shims came w/ mine from ARE.
Old Jun 28, 2002 | 01:22 PM
Fulton 1's Avatar
SSINFUL,
I was trying to get this answer on another thread too, but since you've also installed the Rollmaster I'll ask here too. Did you have to modify the pickup tube at all? Doesn't the bolt hole need to be enlarged?
Thanks.
Old Jun 28, 2002 | 01:28 PM
SSINFUL's Avatar
My engine was *out* of the car when installing, but there was no problem w/ the pickup tube at either end. It's only got a single bolt holding it in place up front.
Old Jun 29, 2002 | 07:03 AM
VAP's Avatar
VAP
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fulton 1:
<strong>SSINFUL,
Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes you are correct the whole in the pickup bracket needs to be slotted as with this double row timing set you are supplied with spacers "about" .080" thick to move the oil pump forward so as to make room for the wider chain & gears - So yes you do have to remove the sump to do this - but its worth it as Rollmaster timing sets are the best in the world in my opinion - Hope this helps - <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 29, 2002 | 10:09 AM
Fulton 1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VAP:
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the confirmation VAP. When you say "remove the sump" that sounds to me like the double-roller needs to be installed with the engine out of the car. Is this correct? With the F-bodies the standard chain can be swapped with engine in car (lowering the oil pan/sump an inch or so helps).
<small>[ June 29, 2002, 10:10 AM: Message edited by: Fulton 1 ]</small>
Old Jun 29, 2002 | 11:00 AM
Quick355's Avatar
I just installed my SLP double roller a couple of days ago. You do not have to slot the holes to make it fit. There is enough movement in the pick-up tube to allow the spacers to fit.
-Allen
Old Jun 29, 2002 | 11:12 AM
Fulton 1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quick355:
I just installed my SLP double roller a couple of days ago. You do not have to slot the holes to make it fit. There is enough movement in the pick-up tube to allow the spacers to fit.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Perfect. That's what I was hoping for. Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
