Anyone have the Grind numbers or P/Ns for all the various Comp Cams lobes?
If you go to there web site, Comp Cams only shows a few LS1 cams.
With all the lobe profiles they have now, there should be a spread sheet or something with [all] the lobe profile numbers and specs that they grind.
Anyone have access to these numbers or tell me where to find them?
Thanks,
Ron
Thanks,
Ron
Hi,
Here are all the Comp Cams lobes I have been able to find. Some lobes are listed but still in-work at this time (like 3711 & 3714). Have you got any others?
Steve
XE-R Xtreme
Lobe#, Dur@6, D@50, Lift
3758, 255, 206, 0.561
3759, 261, 212, 0.578
3760, 265, 216, 0.587
3761, 269, 220, 0.595
3863, 277, 228, 0.612
3720, ???, 220, 0.581
3721, ???, 222, 0.581
3722, ???, 224, 0.581
3723, ???, 226, 0.585
3724, ???, 228, 0.588
3725, ???, 230, 0.592
3726, ???, 232, 0.595
3727, ???, 234, 0.593
3728, ???, 236, 0.602
XE-High Lift
Lobe#, Dur@6, D@50, D@200, Lift
3707, 261, 208, 128, 0.554
3708, 263, 210, 129, 0.556
3709, 265, 212, 131, 0.558
3710, 267, 214, 133, 0.559
3711, 269, 216, 135, 0.561
3712, 271, 218, 136, 0.563
3713, 273, 220, 138, 0.564
3714, 275, 222, 140, 0.566
3715, 277, 224, 142, 0.568
3716, 279, 226, 143, 0.570
3717, 281, 228, 145, 0.571
3718, 283, 230, 147, 0.573
3719, 285, 232, 148, 0.575
3706, 287, 234, 150, 0.576
3705, 289, 236, 152, 0.578
Xtreme RPM
3750, 260, 206, 121, 0.513
3751, 266, 212, 126, 0.520
3765, 268, 214, 128, 0.522
3766, 270, 216, 130, 0.524
3752, 272, 218, 132, 0.527
3767, 274, 220, 134, 0.531
????, ???, 222, ???, 0.532
3753, 278, 224, 137, 0.534
????, ???, 226, ???, 0.535
3755, 282, 228, 141, 0.539
????, ???, 232, ???, 0.542
????, ???, 236, ???, 0.546
<small>[ June 29, 2002, 11:22 PM: Message edited by: SNW Vette ]</small>
Steve
XE-R Xtreme
XE-High Lift
Xtreme RPM
T1 cam specs
Put link instead of image of cam card.
Les
<small>[ June 30, 2002, 02:50 AM: Message edited by: 02 SOM WS6 ]</small>
Les
